Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 13, 2009, 08:11 PM   #1
Personal Sales Rating: (0)
Drives: 03 Lancer OZ, soon to be an evo IX MR, funds almost accumlated:)
AC/heat stuck, won't move. Sun roof problem too.
1) Ok, the knob in my 03 OZ won't turn to its coldest output or to heat what so ever and only gives out one setting of coldest... The knob will only move
a little bit, basically its like its stuck. Its not very cold, and with winter coming, theres 0 heat. Though here in MI, i never use AC.
I bought the car when I lived in AZ. I was told this is a common problem and a local mechanic in AZ told me it was a 400$ fix...but then again, he also told me I needed new brake pads/rotors, new rear shoes, valve cover was leaking and a number of other things... that DIDN'T need changing and WASN'T leaking. He said it was intentionally put that way for whatever reason.
Anyone know what it could be, or where i could get a good deal on parts?
2) One day i pulled in, went to close the sun roof, went half way and started making a crazy rubbing, rattling type noise. Then it would only shut half way, as if it thought it was closed, but its not. Then when trying to get it closed, as rain was coming, the motor just wouldn't stop, making that weird noise, until i disconnected the battery to the car, then pulled the fuse.
Any suggestions?
__________________
"I can't take HIS money, I can't print MY OWN money, I have to WORK for money, why dont I just lay down and die? "
Offline
Old Aug 13, 2009, 08:44 PM   #2
Personal Sales Rating: (1)
Drives: 2002 Lancer es, 1996 chevy tahoe
the hvac controls stick in the lancers. the manufacture knows about it. even put a TSB about it but did not do a recall. pretty much you have to replace your HVAC control panel.
LOL at your mechanic for saying it is a 400$ fix. call up your local junk yard tell them to send you a HVAC control panel. I got one for 100$.
GL
Offline
Old Aug 13, 2009, 10:51 PM   #3
Thanks bro, I'll be doing this very soon. Yah this mechanic really tried to screw me. Wanted 500$ to do everything but the AC/heat thing. I went else where, and found out everything he said was a lie.
__________________
Offline
Old Aug 14, 2009, 06:53 AM   #4
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
The issue you're having with your sunroof happened to me. The solution - the sunroof motor came loose inside the headliner. The bolts holding in place had come loose over the years and the motor came off track. I was lucky enough to have this happen right at the end of my warranty, so it was covered. Hope this helps.
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Old Aug 14, 2009, 08:49 AM   #5
Personal Sales Rating: (7)
blaze_125's Avatar
Drives: Yellow OZ
The ac/heat control knob problem has nothing to do with the control panel. It's the mechanism that stays stuck because crap got in the system.
From the driver side, look where the center console enters under the dash. At that location you will find a white lever. You can move it by hand instead of using the knob and breaking it.
I broke my knob 3 years ago and I just reach under the dash to move the lever and control temps.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Old Aug 19, 2009, 12:37 PM   #6
bzmotoninja83's Avatar
Drives: 02 lancer ES, 97 isuzu rodeo 4x4
i havent looked into it in detail but could it be a broken cable like the galant is suseptable to?
Offline
Old Aug 19, 2009, 02:26 PM   #7
I'm going to take it to a reliable, trustworthly mechanic soon. I have a feeling its the Hvac control panel. We'll see soon.
__________________
Offline
Old Aug 28, 2009, 09:47 AM   #8
blaze_125's Avatar
Drives: Yellow OZ
Quote:
lol, Ok. I guess telling you the facts doesn't cut it... I also guess a known TSB doesn't cut it either. Oh well.
Don't forget to post the mechanic's diagnostic; I'm curious.
__________________
Offline
Old Aug 29, 2009, 10:11 AM   #9
I havn't tried your conclusion yet, but I don't need AC or heat yet. I only want it fixed because I'm selling the car very soon for an evo IX. I quickly looked for the leever what couldn't find it. I'll get under there today.
__________________
Offline
Old Oct 1, 2009, 06:10 AM   #10
Drives: 03 Mitsubishi Lancer OZ Turbo...
Hey everyone, I am new to the forum... Anyways I have this problem right now also. Is the location of this lever shown somwhere in the service manual? And if not does it move left to right or back and forward? Thanks
Offline
Old Oct 1, 2009, 06:14 AM   #11
Personal Sales Rating: (42)
xspsi4's Avatar
Drives: evo 1 gsr/ evo ix mr 5spd
You just need the blue cable behind the hvac it is a cheap easy fix, My evo just had the same problem.
__________________
The good die young and the pricks live forever!
-Lewis black
Offline
Old Oct 1, 2009, 12:42 PM   #12
blaze_125's Avatar
Drives: Yellow OZ
Quote:
Why a manual? You just quoted the post that tells you where it is
It's white, and circular and is pushed/pulled in a circular motion(front to back, or more like top to bottom).
__________________
Offline
Old Oct 2, 2009, 04:15 AM   #13
Cool
Thanks for the answers. Sorry for the dumb question. Got it all working last night by replacing the metal cable from the temp control nob to the lever that moves front to back.. Cleaned out the system also so that helped out a lot.
Offline
Old Oct 2, 2009, 09:20 AM   #14
blaze_125's Avatar
Drives: Yellow OZ
How?
Did you pull everything appart to vaccum whatever had gotten in the pipes?
__________________
Offline
Old Oct 3, 2009, 07:50 AM   #15
Where did you buy the part? I have the temp control cable in my hand right now which is the main problem but i cant find where to buy the part.
__________________
Offline
Tags
05, a, ac, broken, chevy, control, galant, heat, knob, lancer, lever, oz, problems, stuck, sunroof, tahoe
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
