Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 12, 2009, 05:07 PM   #1
Personal Sales Rating: (0)
Drives: 08 Lancer GTS cvt
Need help random stalling
2008 Lancer GTS CVT, got about 39000 miles on it.1st problem other day at work i left the key on for about 7 hours and of course killed the battery, jumped it and it ran fine. now for some odd reason it when i starts it shoots from 400-1500 rpms bounces around then just goes dead, fires back up after ya give it a sec and runs fine. 2nd problem, sitting at traffic light i step of the brake car just stalls, no coughing or sputtering and the accessories stay on, this random stalling has now happened to me bout 4 times in the past week. any body got any ideas on problem? and yes its modded with RRM header, RRM axel back, RRM piggy back and secret weapon intake and crank pulley.
Offline
Old Aug 12, 2009, 05:40 PM   #2
jer301's Avatar
Drives: 2009 Lancer GTS
Quote:
This is going to sound odd but try this. turn the car off (take the key out) and disconnect the positive battery terminal for about 15 minutes or so. reconnect it. i had similar symptoms on a cavalier from a battery replacement. took it to the dealer, two other shops and they could not find the problem. went to a small repair shop my father in law recommended and the mechanic told me to do the same and it fixed the problem. He said someimes when the batt runs dead or is replaced the ecu does not reset itself correctly and the vehicle won't run or idle correctly. I hope this is the issue. if it does not work, you might have to go to the dealer.
Offline
Old Aug 12, 2009, 05:51 PM   #3
ill have to give it try,i also noticed when it does this its always at idle rpms, usually it just stepping off brake and bam... dead, doesnt throw any codes and had all the mods installed for about 25000 miles so ruled out that. and dealer would be scary seeing has i voided pretty much every warrenty under the hood
Offline
Old Aug 12, 2009, 05:58 PM   #4
i also forgot this when i left the car on the engine does the stupid clicking, when i got outta work it was SPAZZING out hard core and when i removed the key it still kept clicking and the only way it stopped was when i disconnected the battery
Offline
Old Aug 12, 2009, 06:02 PM   #5
jer301's Avatar
Sounds more and more like what was happening to me. turn on the car rpms jump up and back down stall out at idle unless you give it gas, etc, etc. I am not sure why it happens but from time to time if the batt goes dead or is either the throttle position sensor or the ecu. the reset worked on my crapalier. give it a try.
Offline
Old Aug 12, 2009, 06:05 PM   #6
jer301's Avatar
That reminds me make sure the key is out, vehicle is in park and all that jazz before you do it.
Offline
Old Aug 14, 2009, 08:15 PM   #7
update. pulled the battery let it sit for about a hour, second day now and so far no problems and its been running like clock work again. hopefully this was the was the problem and if so thanks
Offline
Old Sep 10, 2009, 05:21 PM   #8
update on my lancer problem, no fix, still randomly stalls when sittin either in traffic or at a light. doesnt wanna restart once i shut it down, wondering if this has something to do with the relay problem? looks like ill have to cave in to the dealer to fix this problem
Offline
Old Sep 11, 2009, 05:33 AM   #9
Personal Sales Rating: (1)
Drives: 2008 Grey Lancer GTS (5spd)
Send a message via AIM to kalpakiotis
It sounds like it could be the coil pack. My brother's jetta would do that exact thing if there was any moisture around the thing.
__________________
HID Lo/Hi/Fog
RRM SRI V2
RRM TCM
Works Short Shifter
Megan Coilovers...if interested in the stock GTS suspension, pm me.
Offline
Old Sep 11, 2009, 05:52 AM   #10
2005 Mitsubishi Lancer Evolution
signcutter's Avatar
Drives: 2005 Lancer Evo MR
I'm wondering if your battery is going bad maybe alternator issue not charging your battery completely...start there run a volt tester on it. Factory batteries are not the best...ecu, sensors going bad all of the sudden doesn't make sense unless there was some shorts going on upon jumping...keep us posted
__________________
INTAKE: Turbo XS
CAMS: BC272/272 with JUN Springs & Skunk2 Gears, ARP head bolts
INTERCOOLER: Perrin
BOOST: Hallman Manual
HKS Turbo Back
TEST PIPE: Custom, Vivid Racing
IC PIPING: Custom, Big D.
Walbro 255L/HR with PTE 880cc Injectors
Turbo: ATP GT3071R
Exedy Twin Disc
Suspension: Cusco Zero2E w/e-con & Cusco Rear Bar, Cusco Rear Sway Bar, Custom Under Carriage Braces.
Tune: By Mitch, Vivid Racing
5 speed tranny swap/evo 9 1st gear & Upgraded Tcase.
350/317 MustangDyno, 91pump, @23psi
Offline
Old Sep 11, 2009, 07:36 PM   #11
its weird i noticed it only does it when the the temp drops below 65 which by me is a normal thing this time of year, even after the car is warm i come home turn it off ten minutes later i go back out turning it back on requires hard throttle like its starving for gas, and then i pray i dont hit a light with in the first ten minuts or it stalls again. and when it does i have to basically rev it to red line has i krank it. my first thought was the RRM piggy back, but that has been installed for well over 15k with no problems and nothing but good things to say about it. this problem i am stumped over and the car is becoming a problem to drive now
Offline
Old Sep 11, 2009, 07:47 PM   #12
Personal Sales Rating: (2)
buchnerj's Avatar
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
Thats weird. Maybe the dead battery reset something in your piggyback system. Try disconnecting and going back to the stock ECU setup (if it is practical to do so) and see if it solves things. Obviously performance wise it will be different, but see if you regain the drivability. I would try and diagnose the problem yourself at all costs, I know it might be a bear to drive now, but if it is one of your mods the dealer is going to make you pay, and void the warranty.
__________________
06 Apex Silver MR
80MM FP Green - Ported 73HTA
HKS 272 Cams
Precision 1200cc Injectors
Walbro 255 lph
Hallman Pro RX MBC @30 psi
ARP Headstuds / Conrod bolts
Injen UICP/LICP
Injen Ram Intake - K&N Cone
APS TV BOV
Greddy Spec-V FMIC
Greddy Turbo Headers
ARC Titanium Catback Exhaust
Megan Radiator
Megan O2 Housing - Ported
DC Sports downpipe/catdelete
Okada Projects Plasma Coils
Excedy Twin HD/ Fly
ROBISPEC/// KW3 Custom Clubsports
E-85 Ethanol
Offline
Old Sep 12, 2009, 07:05 PM   #13
i listened to my dads advice on this one and got a alldata.com account pretty much there are multiple causes of the problem, and all of them are ECM related. from throttle error to lack of air. all of which requires dealer updates. the relay problem really doesnt apply unless the temp number drop to single digits. my only solution is remove the piggy back, make it look like new and head on over to my friendly costly dealer and come up with something creative to get them to do the work for warrenty free
Offline
Old Sep 19, 2009, 08:33 AM   #14
after going to the dealer they said pull my piggy back chip and they will work with me with all the other bolt ons installed. they tried to diagnose it and they said when the hooked the car up they couldnt access any system setting via the ecm and that that chip was blocking them from doing anything. i uninstalled the piggy back and bam, car runs like the day i got it, starts up with no problem doesnt stall anymore, and i def did not notice a any drop in horse or torque. they only thing i can figure that chip was not set up properly via RRM
Offline
Old Sep 19, 2009, 12:22 PM   #15
Personal Sales Rating: (11)
jRox's Avatar
Drives: Traded: WW 2008 Lancer GTS || Upgraded: WW 2009 Lancer Ralliart
Send a message via AIM to jRox
Just curious. What dealership did you go to? Have you spoke to RRM about this issue?
__________________
////////// FS: DRL Bypass w/ Relay Harness
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
