Aug 9, 2009, 12:01 AM
Personal Sales Rating: ( 0)
2005 Mitsubishi Lancer
Drives: 2005 oz rally
car wont start
i just installed my new motor and it wont start. everything is hooked up but it will only crank. any ideas?
Offline
Aug 9, 2009, 02:38 AM
Personal Sales Rating: ( 23)
Drives: 06 Evo MR
Wow, I don't even know where to start. Who built it and who installed it? (I'm assuming you on the latter based on your post). Have you ever done this before and what have you tried? Is it an upgraded motor? I'd start with the basics, fuel + spark = ignition. Make sure fluids are in the system, etc. Good luck.
Offline
Aug 9, 2009, 01:15 PM
Personal Sales Rating: ( 13)
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Any CEL? Exactly what yahu said check for spark first off by pulling your plugs and holding the plug against your head and have someone crank the engine and look for spark, make sure you have some kind of noncunductive gloves on or you will be in for a shock!! lol If you have spark then you have to look at compression, fuel, and timing, normally if your timing is off it will show with low compression as well.
__________________
16G Turbo build: Build completed tuning time
Offline
Aug 9, 2009, 01:17 PM
Drives: 97 GS-T (totaled) 35R powered VIII(SOLD!) currently looking for a new beast!
new motor means it could be so many things, or one little thing lol your going to have to go through and make sure everything is 100%
Offline
Aug 9, 2009, 03:45 PM
Drives: 06 Evo MR
Listen to 03lances, OP! He will have good advice for you for sure.
Hey 03lances. I should be good to go by the end of the month, so we might be able to meet then or maybe early Sep. I'll keep you posted!
Offline
Aug 9, 2009, 04:37 PM
Sweet bro that should work out good I am getting the last of my parts for my build hopefully within the next month to two months yaaa!! lol
and jimmhuth if you can run a comp test and post the results
__________________
Offline
Aug 10, 2009, 03:35 AM
alrighty, i figured it out. the fuel isnt get passed the injectors. it will start with starting fluid but after a minute it starts running rough and then dies. they are off of the new motor which was sitting in a junkyard for six months so i'm just going to pick up some new ones. thanks guys.
Offline
Aug 10, 2009, 03:57 AM
Drives: 06 Evo MR
Glad you figured it out, Jim. Best of luck!
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
