Aug 3, 2009, 04:05 PM
Personal Sales Rating: ( 1)
Drives: 2002 mitsubishi lancer ES
issues
im having problems tracking down a weird ticking noise in my 02 es.
i thought it was an exhaust leak but ive check every connection and nothing seems to be leaking.
it sounds like a valve tapping like crazy but only when im above like 2700 rpm so im pretty sure its not a valve.
im stumped and need all the help i can get its driving me frickin crazy.
edit: i forgot to mention it only make this noise when im driving when i just rev it it does it quietly
Offline
Aug 3, 2009, 04:52 PM
Personal Sales Rating: ( 0)
Drives: 2002 Lancer OZ Rally, 2000 Kawasaki Ninja ZX9R
Mitsus make alot of valvetrain noise. Usually its something like a dirty lifter as our lifters can get dirty very easily.
__________________
Drives a Lancer, nuff said.
Quote:
Originally Posted by rpm_ruffryders
Let those that think outside the box do what REAL TUNERS do best...and thats find new ways to keep the lifestyle/scene that you're in ALIVE.
Online
Aug 3, 2009, 05:29 PM
thanks for the reply. im gonna try running some seafoam through it you think that'll help?
Offline
Aug 3, 2009, 05:33 PM
Personal Sales Rating: ( 2)
2002 Mitsubishi Lancer
Drives: 02 lancer oz 74/76/79 Corvettes
I had a noise kinda like that with old engine. What do you use? And are you in need of an oil change because after you run seafoam you need to change your oil. But seafoam did help with my noise. But changing to mobile 1 5w-30 was the trick for my engine. No noise almost at all. Same with new motor no noise yet anyway.
__________________
Budget Turbo :P installed Custom Borla cat back 2.5,Fidanza flywheel, Act xtss, 4g93 intake, injectors 275cc, Auto meter Gauges, Injen CAI,High flow Cat,aeromotive 1:1 fpr, Walbro 255, circle earth ground
on hand 16g6 with 10.5 hotside,Ported&polished head,Megan Racing 3" downpipe, Intercooler and piping, Greddy BOV rs, guage pods, gates racing belt, Forge wastegate with spring, tactrix cables, 16g manifold, oil feed
Needs injectors
Offline
Aug 3, 2009, 05:50 PM
Seafoam can help yes, but only if you put it in the oil. And you dont need to change the oil till recommended timing when you just put it in the oil. If you run it through the intake, the so called "seafoam treatment", you are supposed to change your oil right after. Also, check your oil levels, you'll develop random ticks when the level is low.
__________________
Online
Aug 3, 2009, 10:27 PM
thanks for the replys.
my oil is full and im not in need of a change for another 500 miles.
i use castrol syntech 5-w30
im gonna try out the seafoam and see if that helps tommorow im hopin for the best i cant take that frickin ticking haha
Offline
Aug 4, 2009, 01:00 PM
seafoam didnt stop the ticking smoothed my idle though haha
any other suggestions?
Offline
Aug 4, 2009, 01:07 PM
Your gonna have to dissassemble the head and clean the lifters. Very easy project, no need to drain oil or remove the head from the car. You just take the valve cover off, take off the rocker assembly, and then pull out the lifters and watch this. http://www.youtube.com/watch?v=gKX2pYVO0Ak . I know it isnt our car, but its a mitsu and the procedure works the same. Its really not a difficult procedure. PM me for pics if you want of the disassembled head if you want an idea of how to do it. Just saying.
__________________
Online
Aug 5, 2009, 12:34 PM
ok sounds like im gonna need to make some time in my schedule haha.
how long do you think it should take me?
Offline
Tags
aem, bar, bushings, disassemble, es, knob, lancer, mitsubishi, noise, seafoam, shift, sway, uego  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
