Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 25, 2009, 09:25 AM   #1
Personal Sales Rating: (0)
Drives: 2003 Mitsubishi Lancer
03 Lancer run rough after new plugs
new to Evo.net. So good day to all. Hope someone can be of assist.
Installed new NGK plugs (proper gap) yesterday and car running really rough. Was fine untill I installed new plugs. Installed new wires, still no help. Have went over it again double checking proper install. I know I must be missing something simple but can't put my finger on it. Reinstalled all my old stuff and it run a little better but far from acceptable. It is a 2L "03" Lancer Oz. Could this by any chance be a fuse or computer prob?
Offline
Old Jul 25, 2009, 09:33 AM   #2
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
First off, welcome to the forums!
How many miles are on your engine? The coil packs are more prone to failure once the miles start adding up. Did you put any dielectric grease in the boots before re-installing the coil packs? If you want, you can reset your ECU by removing your negative terminal on your battery for 25min. After you hook it back up and start the engine the ECU will relearn the settings it needs for your engine. This might be a good place to start. Once you start it back up, don't touch it and let it idle for 20min. Then for the next 100 miles or so it will learn it's settings for cruise and WOT.
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Old Jul 25, 2009, 11:11 AM   #3
imalancerman's Avatar
Drives: 2002 Lancer OZ Rally, 2000 Kawasaki Ninja ZX9R
Send a message via MSN to imalancerman
Also check for cracked plugs. I installed new plugs on my grandparents mercury and accidentally cracked one while installing and didnt even know. We replaced so much crap before we figured it out. Just a suggestion.
__________________
Drives a Lancer, nuff said.
Quote:
Originally Posted by rpm_ruffryders View Post
Let those that think outside the box do what REAL TUNERS do best...and thats find new ways to keep the lifestyle/scene that you're in ALIVE.
Offline
Old Jul 25, 2009, 01:44 PM   #4
125480 miles. The parts dealer gave me the wrong plugs first go around and that's when my troulbe started. I've replaced plugs,wires and coil. Still no change. Have been told that installing wrong plugs could have made it jump timing or blown a piston, #3 is not firing
Offline
Old Jul 25, 2009, 01:55 PM   #5
Quote:
Did you replace both coils or just one of them? Wrong plugs would've caused the ECU to make adjustments to get back stable, but should correct itself with the right plugs eventually. If you swap the coils see if the #1 cylinder fires or not. That would indicate a bad coil.
__________________
Offline
Old Jul 25, 2009, 07:16 PM   #6
swap new coil still #3 not firing. Removed positive post for 30 min but car will not idle.
Offline
Old Jul 25, 2009, 11:10 PM   #7
Personal Sales Rating: (13)
03lances's Avatar
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Have you checked your compression on #3? That would be the next step I would take, if its not firing either no compression, no spark or no fuel. Check compression. Pull the plug and connect it to the plug cable and hold it against the head and have someone turn it over to check the actual spark plug for spark, swap injectors (if you can without hurting it not sure) from the #3 from another and see if #3 still doesnt fire to see if for some reason the injector is clogged or toast.
__________________
16G Turbo build:
Build completed tuning time
Offline
Old Jul 26, 2009, 05:23 PM   #8
Question
Quote:
Tested #3 plug it is not firing, swapped out wiring and retested still no spark. Also disconnect battery post waited about 30 min. reconnected and tried to idle, but no success there either. I had absolutely no prob until I installed the wrong plugs, could this have caused my problem. I just can't imagine how it could have went from good to bad in a few moments.
senate thanks for all your help, you've been great!
Offline
Old Jul 26, 2009, 05:38 PM   #9
03lances's Avatar
Ok if you havent already I would take another coil pack and connect it to the #3 harness then connect the spark plug and hold against the head again to retest. If it works its for sure the coil pack if it still does not check with another spark plug again if it works its the coil pack if it doesnt then time to start checking the wiring (and if this is what you meant by swapping wiring then disregard) hope that helps
__________________
16G Turbo build:
Offline
Old Jul 26, 2009, 09:37 PM   #10
It's the negative terminal that needs to be disconnected, not the positive. I would also use dielectric grease on the wire ends hooking up to the coil packs to make sure you have a good connection.
__________________
Offline
Old Jul 27, 2009, 06:21 AM   #11
sorry my bad, it was the neg I removed. Know where I can find a wiring diagram?
Offline
Old Jul 27, 2009, 06:35 AM   #12
Which diagram do you need? There are dozens in the factory service manual.
__________________
Offline
Old Jul 27, 2009, 07:14 AM   #13
which ever one sends fire to #3
as u can probably tell I'm NO mechanic
Offline
Old Jul 27, 2009, 10:47 AM   #14
I need to know if you have a manual or auto trans to know which diagram to put up for the wiring, but here's two diagrams that should help you out diagnosing the coils, if one of them is bad:
__________________
Offline
Old Jul 28, 2009, 02:51 PM   #15
03lances's Avatar
Any luck on troubleshooting?
__________________
16G Turbo build:
Offline
Tags
02, 03, 2003, bad, coil, coils, cylinder, firing, jump, lancer, mitsubishi, pack, plug, spark, timing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
