Brakes issue
So I started getting an repetitive rubbing noise from my back end a while ago.
About a year ago, my back brakes started vibrating (no vibration in steering).
I had the drums and shoes changed but that didn't help.
Eventually my brakes started vibrating under medium braking (steering wheel vibrating). Under light breaking (slowing down) they're fine, under harder braking, they barely vibrate.
Recently I started losing brake fluid. I have to top it up about every 2-3 weeks.
There are no no drips on the ground so I'm thinking this must be a slow leak, happening only when I break.
The tires seem fine, no uneven wear, no vibration issues at any speeds.
The rotors, pads, calipers, drums and shoes have all been changed and do not seem to have had any influence over this issue.
So here are my questions:
1 - where could I be losing brake fluid?
2 - what could be causing the vibrations under medium braking (other than the obvious)
Thanks,
