Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 6, 2009, 09:24 PM   #1
Personal Sales Rating: (0)
oakley198877's Avatar
Drives: 03 silver es 5spd
Question HID kit with relay harness, weird problems
Well, I've been working on this problem since two weeks ago and was hoping someone on here can help me out. I got this Hid conversion kit for my 03 ES, and long story short, after installing it, when i turn the lights on, it would just flicker and turn off in like in 1-2 sec. I figured maybe I needed a relay kit.
After connecting the relay harnesses on both ballasts, it worked perfectly, at least I thought so. As most of you know, the relay kit only connects to one of the OEM bulb plugs (plug A) to control on/off, which means I have only one of the two original plugs used. When I first connected and tested the relay kit, the other plug (plug B) still had the original 9007 halogen bulb on it. That test worked.
However after I fully installed everything and unplugged the OEM bulb from plug B (plug B now has no bulbs connected) both HIDs would not light up. I spent a lot of time trying to figure out what went wrong. And by some strange coincidence I found that when I plug the original 9007 halogen bulb back on plug B, both HIDs work.
Now, I don't understand what is going on here, the relay kit (connected to plug A) needs the other bulb (connected to plug B) to work? Obviously I don't want a extra bulb shining in my engine bay, so what can I do? someone said maybe I can buy a resistor to fake it as the OEM bulb, but what kind of resistor would that be? what ohm? what watt? and how do I put it on? is it safe that way? because the last thing i want is problems with my only car. I really hope someone can help me, it is a really strange problem. Thanks in advance.
Note: the original OEM 9007 halogen bulb are 12V with 55W/65W
Offline
Tags
9007, buy, harness, hid, hids, kit, kits, problem, problems, relay, setup, starting, troubleshooting, turn, vs
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
