Jul 2, 2009, 02:33 AM
Personal Sales Rating: ( 2)
Drives: 2003 Rio Red Lancer ES
Lancer doesn't start sometimes
Sometimes when I shut my lancer off for about 20 minutes and go to start it back up, it doesn't start. I turn the key, all the lights turn on and all I hear under the hood is one click. I can try it like 15 times and it won't work and then try it again and the car starts up fine without hesitation. Also, when the car will not start, when I use the remote start for my car, it starts right up. Any ideas? thanks
Offline
Jul 2, 2009, 08:47 AM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
Quote:
Check the terminal connections on your starter real good. Might have some corrosion on them.
Offline
Jul 2, 2009, 11:59 AM
Personal Sales Rating: ( 13)
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
+1^ also check your battery connections and your main grounds that go to your motor and body, I would put money on connection issue
__________________
16G Turbo build: Build completed tuning time
Offline
Jul 2, 2009, 12:43 PM
Does anyone have a diagram of the starter so I know where to check for corrosion? It's kinda hard to stick my hand back there and find every spot it could be.
Offline
Jul 2, 2009, 01:07 PM
Better if you just remove your starter. It will make it easier to clean the terminals. Use some anti-corrosion spray on the connections after also.
Offline
Jul 8, 2009, 10:17 AM
Personal Sales Rating: ( 7)
Drives: Yellow OZ
You just gotta look at where the power/ground cables are located.
Also make sure the nuts holding down the cables are on tight.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Jul 8, 2009, 10:20 AM
And not rusted too, I worked on a car about 2 months ago they let it sit for over a year not knowing why it wouldnt turn over. Well after testing the starter and cleaning it all up it turned out one rusty nut that held the ground wire on the starter caused the whole thing!!! They didnt even have to buy a new nut I just wire wheeled it lol
__________________
Offline
Jul 17, 2009, 10:49 AM
Alright what would be the easiest way to pull it out? I am going to try and tackle my problem this weekend. Is there any way to test it when it is pulled out?
Offline
Jul 17, 2009, 11:23 PM
anybody?
Offline
Jul 18, 2009, 01:01 AM
Send me your email address I can send you something that should help you alot
__________________
Offline
Jul 18, 2009, 05:55 PM
Offline
Jul 18, 2009, 09:53 PM
email sent
__________________
Offline
Jul 19, 2009, 04:53 PM
Thank you man that helps a ton!
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
