Hi,
I just bought a used '03 OZ. There are a few little items I'd like to get worked out and I've never had a Lancer before so any help would be appreciated
. In the engine compartment fuse box there appears to be 3 fuses missing...unless they're for features my car doesn't have, I'm not sure. Number 11 (Condensor fan motor), number 25 (Daytime running light), and number 6 ( Front fog lights) are all empty. I just got the description of the fuse number from the owner's manual, I have no idea if they're correct or not.
I also pulled two trouble codes off the the ECU. P0421 and P0183. I found all the info I need on the first code and I'm pretty sure this vehicle was never taken in for the recall so that's not a problem (except it has 130K mile so it may not be free
). But I couldn't really find a root cause for the second code. I understand it's reporting high input from the fuel temp sensor...but what does that mean? Loose connection? This sensor is attached to the fuel pump right? I wouldn't want to have to change the whole pump just to get a mal-functioning sensor to work. I checked connections on the ECU already but I'd like to double-check the connection to the sensor. Can anyone give me some info on how to access it?
Thanks!
