Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 13, 2009, 05:37 PM   #1
Personal Sales Rating: (1)
MisterStrike's Avatar
Drives: 2009 Lancer ES-Sport
Injen Cai Install + Maf O-ring (pics Included)
So sometime last year I took my Injen CAI off due to it throwing a cel about 2 months after it was installed. I assumed that I had I simply done something wrong or something came loose. This weekend I decided to put it back on since I needed to get a new air filter anyway why spend $50.00 when I have $300.00 one in the closet? So I installed it making sure everything was tight when I went to put in the MAF I noticed that the o-ring was stretched out. I know I was very careful taking it out of the factory box and putting it in Injen during the original install and when I switched it back so I am not sure what happened this time. Anyway I could not get it to go into the intake because it was so stretched. I had given up and was about to start putting the factory box back on but before I did I tried to get the MAF into the factory box as well and it would not go in that one either. I ran to a local O'Riley's and they gave me the only o-ring they had that would fit (Literally gave me three of them for free). The one they had was quiet a bit thicker then the factory one and it also would not fit in the intake or the factory air box. I did bolt the MAF up to the intake to see what it would do. I started the car and let it sit for 15 minutes and then drove the car down the highway. The car ran fine but the o-ring is squashed between the MAF and the Intake. I have included pictures. I would like to know if you guys think this will work, at least until I can get a factory o-ring ( I called Mitsubishi and as normal they were no help and actually told me to go to a local store because they do not stock o-rings.) Well your thought guys?
http://i135.photobucket.com/albums/q...e/DSCF2902.jpg
http://i135.photobucket.com/albums/q...strike/Top.jpg
http://i135.photobucket.com/albums/q...rike/side1.jpg
http://i135.photobucket.com/albums/q...ke/side2-1.jpg
__________________
Do you want to ride with Batman?
Greddy Ti-C Exhaust
Injen CAI
Offline
Old Jun 17, 2009, 10:18 AM   #2
Personal Sales Rating: (0)
Drives: 2008 Lancer GTS 5 spd w/ sun&sound
shop around, you should be able to find the correct size o-ring, and try a diff mitsu dealership...they don't stock o-rings, how stupid.
Offline
Old Jun 17, 2009, 05:19 PM   #3
Drives: 2008 Grey Lancer GTS (5spd)
Send a message via AIM to kalpakiotis
I wouldn't be concerned about the oring, the point of the oring is to prevent leakage. Having a thcker one will do the job. The only thing i would worry about i the MAF sitting square square since its only held in place by 2 screws
Offline
Tags
08, 09, 2002, 2008, cai, es, injen, install, installing, intake, lancer, maf, needed, oring, orings, tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
