Quote:
Originally Posted by jer301
If the holes are for some type of dissimilar metal (aluminum bolts and nuts) and the metal car parts that you drilled are a steel alloy I would remove the silicon and use a zinc rich antisieze compound or wet zinc primer between the dissimilar metals. Once primed find some type of polysulfide sealant. Be sure to get a good coat on it. This should minimize any corrosion problems for a long time.
the part fitting into the hole is plastic (infact the whole bodykit is plastic)... its just a plug being slightly wider than the hole so it goes straight in and straight out (with force)
Quote:
ya just make sure whatever metal you made bare, gets covered back up again
i really globbed it on so that there should be around a 1cm excess around the hole in addition to covering the bare metal.... but there was also a thin layer of wax i (stupidly) didn't remove beforehand.
i wouldnt say the holes are exposed directly to the environment... ie: even if you tried you wouldnt be able to find them without removing the bodykit. however there are gaps and the likes which may allow moisture in (there are drainage holes too). so if theres damage i can't see it and will probably never know until its too late.
the fact that i globbed it on and that i can't get easy acess to them is whats causing me to hesitate replacing the sealant in the 1st place. i also can't get a solvent in there (unless i literally pour it into the gaps and hope it hits).
ill essentially have to "rip" it off and hope it comes off clean.
