Apr 2, 2009, 03:45 PM
Personal Sales Rating: ( 0)
2009 Mitsubishi Lancer
Drives: 2009 Lancer GTS
2009 GTS Front Emblem
Hi;
I'm planning to remove the fron Emblem on my GTS to replace with the Colt-Speed Emblem. Are there anyone knows how to remove the front Emblem...??
Many Many Thanks...!!
__________________
'2009 GTS - Octane Blue CVT
- Advan RS Gold
- Eibach Pro-Kit F1.2" & R0.8"
- Colt-Speed Hood Dampers
- VG Functional Sharkfin Antenna
- 25% Tint
Online
Apr 2, 2009, 04:38 PM
Personal Sales Rating: ( 6)
2008 Mitsubishi Lancer
Drives: Boosted 2008 Mitsubishi Lancer
yep, just pulls right off. it uses double sided tape to stick on. use a knife though to slide under it and "pry" it off, but be careful...i broke mine. luckily i like the look
__________________
2008 Lancer GTS 5-speed
FIRST XtremeBoost turboed Lancer, tuned by Jestr
240 whp
228 wtq
...on a mustang dyno
HAD the world's fastest 2008 Lancer
http://www.cardomain.com/ride/3070504
Offline
Apr 2, 2009, 10:34 PM
Personal Sales Rating: ( 1)
Drives: CJ Lancer
I've actually been thinking of doing this for awhile too! I want to change both the front and the back but it's the front that's abit worrying since I don't know if there's a way. The logo doesn't seem to fit right over the triangle where the diamonds are sitting now. Could you perhaps update us when either of you do it and show what it looks like?
__________________
Mitsubishi 2008 Lancer Olympic Edition
Offline
Apr 3, 2009, 01:21 AM
hee~ I'm a bit worry for the front... so I only order the one for the back...^^"
I will post some picture when I'm done..^^
__________________
- Advan RS Gold
- 25% Tint
Online
Apr 3, 2009, 09:30 AM
Quote:
i cant show you...i broke mine in the process of taking it off. but that was probably because i rushed. you can do it with patience and a knife to help unstick it from the plastic. really, all it is is double sided tape.
I was going to paint it flat black anyways to match my bumper, so it looks alright with no emblem at all, because behind the emblem, the plastic is raised to conform to the emblem, so there are still 3 diamonds lol good luck
__________________
240 whp
228 wtq
Offline
Apr 3, 2009, 10:48 AM
Drives: 2008 Lancer DE WW
Best way I was thinking was, buying RRM's front grill replacement and put the colt speed emblem there.
__________________
Quote:
Originally Posted by zl1560
These unpleasant thoughts of looking cheap go away when I push the happy pedal.
Offline
Apr 3, 2009, 10:54 AM
Drives: 2006 lancer oz rally
If you heat up the 3m tape that helps a lot then stick like a criditcard or some thing hard to take off for the back but for the front you could use a knife
__________________
I like "subARU"/ "URAbus" ekil I
Offline
Apr 3, 2009, 11:41 AM
Drives: Apex Silver 2008 Lancer GTS
for removing the rear use fishing line. It will be able to get close to the paint and not damage anything. for the front im not sure but do it on a warm day when the sun has been on the front of the car for a while and it should be easier to get it off. warm day applies to both front and rear.
__________________
RRM SRI Intake
RRM Rear Strut Tower Bar
RRM Carbon Fiber Mirror Covers
RRM Carbon Fiber Splitter
RRM Emblem on rear
RRM Timing Module
Partially Debadged rear
Limo Tint on rear
Vortex Generator
Nikon D80 with Nikkor 18-55mm lens and 55-200mm lens.
Offline
Apr 3, 2009, 11:49 AM
thanks for all of you.... seem like warm day with sun is the key... then I properly wait until Summer.... it's still cold in Vancouver ...^^"
__________________
- Advan RS Gold
- 25% Tint
Online
Apr 3, 2009, 11:57 AM
Quote:
That's a solution.... but it cost over $2XX..... kinda too much for solving the emblem problem.. ^^
__________________
- Advan RS Gold
- 25% Tint
Online
Apr 3, 2009, 12:38 PM
Drives: 09 ES
Quote:
exactly what I was going to suggest, or for heat use a heat gun..I have never used a heat gun near paint so it might be stupid to do so, but ive read that is an option for days when its cold.
Just putting that out there, if anyone has used it a heat gun or know more about it then correct me.
Offline
Apr 3, 2009, 12:46 PM
Iforgot to say you can use a blow dryer also instead of the heat gun like the guy above said that's what I did to my lancer emblem and just go to an auto part store and get some goo gone to remove any sticky stuff that is left
__________________
Offline
Apr 6, 2009, 03:12 PM
Drives: 08 Lancer ES MT
How does this emblem look like? Can someone post a pic.
__________________
2008 Electric Blue Lancer - 5 spd
☑ Works Rear Sway Bar
☑ HKS Drop-In Filter
☑ 17x8 Rota DPT / Falken FK-452
☑ Rally Armor Basic Mud Flaps
☑ 20% Tint
☑ DDM SlimLine 4500K HID with DRL defeat harness
☑ Fog Light Kit
Offline
Apr 6, 2009, 07:21 PM
__________________
- Advan RS Gold
- 25% Tint
Online
Apr 7, 2009, 06:55 PM
Drives: 2009 Lancer GTS CVT
use zip ties its better than a knife and you wont scratch up the grille
__________________
[X] Tsudo N1 Axle Back Exhaust w/o Resonator
[X] AEM Cold Air Intake
[X] Tein S-Techs
[X] Ingalls Camber Kit
[X] Tint-Protector Felt Moleskin
[X] 5% Rear , 35% Front Window Tint
[X] Evo X Nose
[X] ARS Rear Lip Diffuser
[ ] RRM Side Mount Plate
[ ] CVT Turbo
Offline
Tags
2009, car, colt, emblem, emblems, evo, front, grill, gts, lancer, logo, mitsubishi, red, removal, replacement, speed  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
