Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 12, 2009, 08:26 PM   #1
Personal Sales Rating: (1)
nj_08_gts's Avatar
Drives: TB 2008 Lancer GTS, Spec Miata
Send a message via AIM to nj_08_gts
Engine Weirdness
Semi tough situation to describe: While braking, has anyone experienced: Engine RPM's "sticking" around the 1200 - 1000 mark; and then, when almost at a complete stop, RPM's drop so low (~500) the car sputters a little bit. Shortly thereafter, the car returns to normal idle speed (~750ish). Then, if I take my foot off of the brake, instead of smoothly idling forward, it's jerky and hesitant.
There are about a million things that could cause that, but it's cold out and I'm lazy. Anybody run into anything similar? What was done to resolve it?
The problem has been ongoing...one day it just started happening and happens irregardless of temperature (no real mods to the car, either).
__________________
"Speed has never killed anyone - suddenly becoming stationary, that's what gets you."
- Jeremy Clarkson
Offline
Old Feb 12, 2009, 08:28 PM   #2
Personal Sales Rating: (0)
I Am God's Avatar
Drives: 09 Black GTS M/T S&S
cvt or 5spd
Offline
Old Feb 12, 2009, 08:38 PM   #3
MasterAK's Avatar
Drives: 08 Lancer ES MT
The previous situation has also happened to me before, except the last part about taking the foot of the brake etc... However since it happens rarely I haven't done anything about it.
__________________
2008 Electric Blue Lancer - 5 spd
☑ Works Rear Sway Bar
☑ HKS Drop-In Filter
☑ 17x8 Rota DPT / Falken FK-452
☑ Rally Armor Basic Mud Flaps
☑ 20% Tint
☑ DDM SlimLine 4500K HID with DRL defeat harness
☑ Fog Light Kit
Offline
Old Feb 12, 2009, 08:48 PM   #4
nj_08_gts's Avatar
Quote:
Originally Posted by i am god View Post
cvt or 5spd
cvt
__________________
- Jeremy Clarkson
Offline
Old Feb 12, 2009, 10:59 PM   #5
Personal Sales Rating: (11)
jRox's Avatar
Drives: Traded: WW 2008 Lancer GTS || Upgraded: WW 2009 Lancer Ralliart
Send a message via AIM to jRox
I think I felt that too on my 08 CVT GTS.
At a stop, I would let go of the brake and have the auto creep forward without pressing on the gas. I would feel the car bog, sorta like a knock. Like it feels like it's accelerating a little, then not, then accelerate, then not, and so on.
I never brought it in to the dealer to get it checked out cause I didn't know how to explain it to them.
Didn't happen all the time though. Just randomly.
__________________
////////// FS: DRL Bypass w/ Relay Harness
Offline
Old Feb 13, 2009, 05:02 AM   #6
nj_08_gts's Avatar
That's exactly it. I think you did a better job of explaining it than I did
__________________
- Jeremy Clarkson
Offline
Old Feb 13, 2009, 06:23 AM   #7
Drives: 2008 Grey Lancer GTS (5spd)
Send a message via AIM to kalpakiotis
Its just the computer maintaining some parameters in the engine. Happens in my car all the time, especially when coming to a quick stop, hit the clutch and the rpms kinda just hang then fall. I think ive seen it get down to almost ~250 one time then just readjusts and maintains ~750 for an idle. I'm not really concerned about it since it has been doing it over the entire life of the car.
Offline
Old Feb 13, 2009, 06:27 AM   #8
Drives: 2008 Lancer GTS
I've had the same problem as jRox, apparently it is the ecu trying to calculate and run the car at best fuel efficiency. When it see the rpm high, it will try to reduce it but when it drops too low then it increases rpm to keep the same vehicle speed. My driving habits are aggressive but when installed the SRI I had to reset the ECU and the "bogging" would disappear. However, have the ECU has learned my driving habits again it will start to bog at low speed i mean like 5-10km when you are stuck in traffic.
Offline
Old Feb 13, 2009, 09:57 AM   #9
jRox's Avatar
I believe Mitsu released a ECU flash for the 'no start' problem. Trying seeing if you can get the ECU flash. Maybe that would fix it? Worth a try. lol
__________________
Offline
Old Feb 13, 2009, 11:36 AM   #10
The no start is not a flash just a swap for a relay, if there was i wasn't aware of it. Anyways i had that done and the problem is still there
Offline
Old Feb 13, 2009, 01:59 PM   #11
Drives: 08 RR Lancer GTS - CVT
Does it happen shortly after starting the car up for the first time of the day? It does that to me when I put it reverse right after being started sometimes. I've never noticed it while stopping and going though.
Offline
Old Feb 13, 2009, 03:09 PM   #12
nj_08_gts's Avatar
Quote:
No, it happens throughout the day. If you let your car warm up a bit more, it might solve your reverse problem, though.
__________________
- Jeremy Clarkson
Offline
Old Feb 13, 2009, 03:15 PM   #13
Personal Sales Rating: (2)
Drives: 2009 Lancer GTS BLK/BLK , 2008 Mitsubishi Lancer Es
Send a message via AIM to lancer0220
sounds like the CVT. thats pretty much what it does in mine when i left off the gas. did the same in my parents 08
__________________
2009 Black Lancer GTS S&S, OEM EVO X hood , EVO X Recaro Seats, 2.4L Injen CAI, 18x8 MSR 045 225 40 HP Fierce tires, Carputer w/ 7" touchscreen running Centrafuse 1.47, Blacked out grille , Autopager 2 Way Alarm, Escort Passport 8500 X50 with ZR3 Laser Shifter, 20% Tint
Offline
Old Feb 13, 2009, 03:33 PM   #14
Personal Sales Rating: (6)
yitzac1990's Avatar
Drives: Boosted 2008 Mitsubishi Lancer
Send a message via AIM to yitzac1990 Send a message via MSN to yitzac1990
another reason why you buy a good 'ol manual haha
__________________
2008 Lancer GTS 5-speed
FIRST XtremeBoost turboed Lancer, tuned by Jestr
240 whp
228 wtq
...on a mustang dyno
HAD the world's fastest 2008 Lancer
http://www.cardomain.com/ride/3070504
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
