Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 31, 2009, 02:22 PM   #1
Personal Sales Rating: (0)
Drives: 2008 Lancer
Rear sway bar
I just got a hold of some parts off a wrecked GTS, installed all 4 discs with calipers no problem, but after installing the rear sway bar the car is 1 inch higher on the rear right, does anyone have an idea why, is there any special adjustments????
Offline
Old Jan 31, 2009, 05:49 PM   #2
Personal Sales Rating: (1)
nj_08_gts's Avatar
Drives: TB 2008 Lancer GTS, Spec Miata
Send a message via AIM to nj_08_gts
One inch higher from where? Are you talking about the wheel/fender gap or the distance from the frame to the ground?
__________________
"Speed has never killed anyone - suddenly becoming stationary, that's what gets you."
- Jeremy Clarkson
Offline
Old Jan 31, 2009, 07:54 PM   #3
Drives: 2008 Lancer
thanks, from the wheel to fender, I also checked tire pressure and made sure the surface was even! I didnt measure it before the stabilizer install, but I never noticed it before!
Offline
Old Jan 31, 2009, 08:03 PM   #4
Juan Martinez's Avatar
Drives: 03 Mitsubishi Lancer Oz Rally, 04 Mitsubishi Lancer ES
Send a message via Yahoo to Juan Martinez
Quote:
Check your mounting points and make sure the angle is good, Before you tighten the sway bar links, place the car on level ground. I hope this helps.
__________________
Build Thread http://forums.evolutionm.net/lancer-...ld-thread.html
Check out my rides at
http://www.cardomain.com/id/k_dog007
03 Lancer OZ Rally
04 Lancer ES
98 Eclipse RS (Traded in July 2007 for 04 Lancer)
01 Mirage ES (Traded in on Eclipse in 2005)
85 Pontiac Fiero (never made it on the road, sold 2004)
93 Eagle Summit ES (Traded in in July 2003 for 01 Mirage)
Offline
Old Jan 31, 2009, 08:13 PM   #5
Drives: 2008 Lancer
hey thanks, I did have the up on jacks and uneven when I installed and tightened the bar. I'll do that first thing in the morning and post the outcome.Thanks.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
