Mar 22, 2008, 08:10 AM
Personal Sales Rating: ( 0)
power windows not worcking
anyone had issue with PW
i've check the fuse it's good
anybody knows how to test the switchs
or have a elec. diagram
Offline
Mar 22, 2008, 08:30 AM
can't find a tread that could help
any clue?
evrebody's windows worck fine
Offline
Mar 22, 2008, 09:06 AM
Personal Sales Rating: ( 3)
2002 Mitsubishi Lancer
Drives: 02 Lancer OZ Rally Sport
My windows work fine, haven't heard of anyone else having problems. Were yours ever slow up or down, or they worked great one day and not at all the next day?
Offline
Mar 22, 2008, 09:11 AM
Personal Sales Rating: ( 53)
Drives: 03 Evolution 8
my wondows always worcked fine. did you install anything electrical lately?? check and make sure you dident cut a wire or something.
maybe the motor went bad?? or is it all the windows that dont worck???
if you took the door apart maybe you dident connect the plugs good enough.
__________________
JESTR TUNING - FULL-RACE - SPARK TECH - NISEI ENGINEERING - DRIVEN INNOVATIONS - DOG BOX RACING - MPFab - MITSUBISHIPARTS.net
NEW JERSEY EVO OWNERS *THREAD*
My F/S thread STOCK & AFTERMARKET *CLICK HERE*
WTBWTBWTBWTB : Evo RS door handles
Offline
Mar 22, 2008, 09:19 AM
Wait a second...I just looked at what he drives...Does your snow plow even HAVE power windows?!
Offline
Mar 22, 2008, 09:33 AM
they worck one day not the other
the snow plow is a joke we recived around 11feets of snow this winter
so gess what i've done this winter
i drive lancers 03 04 and 06 all ES
Offline
Mar 22, 2008, 10:21 AM
i don't have windows no light in the dash and the power doors are worcking
no rear def.
Offline
Mar 22, 2008, 12:06 PM
definately sounds like a fuse. If you know what fuse it's supposed to be, you should replace it even if it looks ok. I've had a fuse blow that still looked in tact because it didn't blow right in the middle where the little view is. Otherwise, there may be a control unit for those items somewhere that could have gone bad or become disconnected. I have a repair manual CD but a friend is borrowing it right now. Once I get it back I'll see if I can find anything in there. Good luck.
Offline
Mar 22, 2008, 12:24 PM
i've replace the fuse
still not worcking
where can i get that CD
i'm in a other country
north....
Offline
Mar 22, 2008, 12:43 PM
I got my CD from eBay and there is one available on there now. Usually the repair manual CD costs $100+, but the one on eBay is listed much cheaper than that. My guess is it's a copy (big no-no for copyright infringement) but that's a choice for you to make. I will say this CD is extremely helpful and if you plan on doing any significant amount of work on your car it would be well worth the purchase for $100 or otherwise.
Here's the link for ebay: Cheap CD Repair Manual
Reason: added link to ebay listing
Offline
Mar 22, 2008, 06:26 PM
thanksfor the link
i've bit on it
tomorow i'll check inside the door if something is f$%ked
Offline
Mar 22, 2008, 06:40 PM
No problem. Good luck.
Offline
Mar 24, 2008, 05:18 PM
they are still not cooperating
stupid windows i'm just ascking to move a little
like up'n down!
i nead f$%king help!
Offline
Mar 25, 2008, 11:01 AM
Drives: 2004 ES
Dude relax, it's easy. You need to test for power at the connector to the motor while pressing the up/down button on the master switch. If present, the motor is at fault and should be replaced. If there is no power, you have a bad switch/connector/wire.
Offline
Mar 29, 2008, 10:28 AM
i check the fuse, theswitch, the connector
the door lock is ok, the miror are ok
can't figure how to worck out those windows
i tried a lot of thing ! i don't know what to do
any help out there?
i'm sitting in the car checking out stuff
so any help would be apreciated
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
