Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Troubleshooting
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 10, 2002, 10:04 PM   #1
Personal Sales Rating: (0)
lanevorockz's Avatar
Send a message via ICQ to lanevorockz
Unhappy Inportant Lancer GLX 2WD to 4WD conversion
Does anybody knows about the 2WD to 4WD converion for a 98' Lancer GLX.
I have seen some infos about it can anybody give a sugestion or a price ( just the parts ).
anybody knows Links about this kind of conversion ?
Offline
Old Apr 10, 2002, 10:35 PM   #2
Lan Evo's Avatar
Send a message via ICQ to Lan Evo
As I have posted in some other posts/threads, this conversion will require cutting the cars rear floor panel (part of rear passenger seats and part of the trunk) and re-welding a AWD (EVO or Lancer GSR) floor panel with the AWD fuel tank back in place.
Since the FWD Lancer fuel tank and floor panel will not aollow the rear transfer case and the drive shaft to fit, you will have to do such procedure....
To get the parts, it's not that hard and expensive; however, the cost of good quality labor will be high. You will need to line up everything perfectly in order for the car to "drive right"....
You're in Brazil, right? I don't know how much would that cost then....
Hope this helps
Offline
Old Apr 13, 2002, 11:12 PM   #3
Thanks a Lot Lan Evo
the labor shouldnt be a problem
its far to cheap
but still have one problem ..
Where to buy the awd conversion parts ??
Offline
Old Apr 14, 2002, 10:20 PM   #4
Lan Evo's Avatar
Quote:
I guess you understand that you can't just use one component to complete the whole job. Given that you can find a EVO IV + 4G63 engine, you should be able to locate the transmission (gearbox) and drivetrain (front & rear transfer cases, drive shaft, all 4 axles) and new suspensions and brakes since the old one won't work with the EVO drivetrains....
You should be able to find them at junk/salvage yard in Japan, UK or Australia.
Offline
Old Apr 17, 2002, 12:16 PM   #5
The section of trunk floor that needs to be cut out isn't actually that large but there is still quite a bit of fitment involved.
Here is a site with some nice pics of the AWD conversion in progress.
Pics of an AWD conversion in progress
Offline
Old Apr 17, 2002, 11:13 PM   #6
But can I have a base price ?
Offline
Old Apr 17, 2002, 11:23 PM   #7
Lan Evo's Avatar
The price varies a lot due to the damaged car condition, milage, age (which EVO) and other aspects....From US$3,000 per car to $16,000+ per car...
Here is a link for a junkyard in UK....
http://www.importcarparts.co.uk/
Offline
Tags
2wd, 4wd, 98, awd, conversion, conversions, evo, gearbox, lancer
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
