Jul 24, 2009, 08:24 AM
#31
Personal Sales Rating: ( 0)
Drives: Lancer oz rally
Very true but if someone gets a cel for their first o2 sensor and not their second one on the cat.What is that telling you? Because a check engine light eliminator doesnt go on your first o2 sensor
Offline
Jul 24, 2009, 08:58 AM
#32
Personal Sales Rating: ( 7)
Drives: Yellow OZ
Quote:
Originally Posted by Boeturbolancer
causes no problems with the car... however if something else does occure then you won't know as the light will already be on.
Boeturbolancer ?
Wow, that was a looonnnnngggggg time ago  I wonder what's his troll name?
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Jul 24, 2009, 11:56 AM
#33
Drives: 2002 Lancer OZ Rally, 2000 Kawasaki Ninja ZX9R
Its telling me that you need to replace that front 02 sensor. It would throw a code if you put a CEL eliminator on the front one because it wouldnt be reading enough of the emissions.
__________________
Drives a Lancer, nuff said.
Quote:
Originally Posted by rpm_ruffryders
Let those that think outside the box do what REAL TUNERS do best...and thats find new ways to keep the lifestyle/scene that you're in ALIVE.
Offline
Jul 25, 2009, 01:32 AM
#34
Drives: 2003 Mitsubishi Lancer OZ Rally
Quote:
Originally Posted by imalancerman
Seemed to work fine for me. But I also have both cats removed. I assume that because of the second cat, there is more backpressure over by that second 02 sensor forcing more of the emissions up into the little CEL eliminator and it basically becomes useless. You kinda get what Im saying? I dont really know how else to explain it but it seems to make sense. Seems like anyone that has that second cat seems to have a problem with the CEL eliminator. Ive only had one 02 cel and it was for the heating element in the 02 sensor cause I twisted the wires when I took the sensor out of the stock header and it must have broke something. Bought a new sensor and it went away.
Ahh I bet your right that makes sense I never thought of that. However that won't help me pass smog test this month if I do that.
But I'll have to try that after thanks! I bet that will take a little of thar back pressure off too...
Offline
Jul 25, 2009, 02:13 AM
#35
Be careful removing backpressure from your vehicle. Remove too much and you'll lose your torque.
__________________
Offline
Jul 26, 2009, 09:31 AM
#36
Great point. Ill try it out
Offline
Jul 27, 2009, 05:35 PM
#37
Right but removing the cat shouldn't do that? Not to much anyways...?
Also how does the RRM header remove the first cat? Excuse my noobish question I just don't understand that.. It's only a one piece... Do I swap (excuse my lack of terminalogy) the piece behind the header right before the cat...? And this is how I get rid of the cel light? (with the cel eliminator also) .. Am I way off here?
Offline
Jul 27, 2009, 05:39 PM
#38
Personal Sales Rating: ( 67)
Drives: faster than you know!
Quote:
Originally Posted by pumpdog720
Who here that have the RRM Headers has had there check engine light come on after it is installed, and what can be done to make it go off if it does come on?
CEL eliminator installed in the second (under the car) 02 sensor hole should fix it. Understand though as these cars get older, often the sensor itself is getting out of calibration and therefore, it could cause an issue. IF you need to call us, we can help you out.
ROAD/RACE
__________________
ROAD///RACE MOTORSPORTS-http://www.roadracemotorsports.com
CARBONTRIXhttp://www.carbontrix.com
Quote:
Originally Posted by LegendsoWicked
Take two....
Mistakes Ive seen and done in the past kept me more cautious and aware this time around. RRM does lancers with attention to detail and so I stuck with them this time.
[/IMG]
NOT A WEBSITE, BUT WE DO HAVE A COUPLE OF THEM
Offline
Jul 28, 2009, 12:44 AM
#39
Use the cel eliminator to get rid of the cel light. The header essentially removes the cat as it connects directly to the downpipe. Is it legal? no. Do we do it anyways? yes.
__________________
Offline
Aug 24, 2009, 02:57 AM
#40
Drives: 2004 Mitsubishi Lancer ES
Okay this thread is freaking me out.
Not kidding. I just bought an OBX header on ebay for a rocking price
and my dad was STRONGLY against it saying how hard it would be messing with the exhaust stuff that has rust on it. So I decided earlier not to buy it....then my dad checks it and decides to bid a couple dollars up and next thing I know I log in and I won the thing. So I tried to comfort myself with thinking of taking it along with a catback exhaust to an exhaust shop. However now I'm freaked out thinking that the CEL might come on or that (like someone said) it's illegal to take off the catalytic converter for the header.
 I'm lost. Can someone please comfort me with some information because otherwise I might just sell the OBX headers . . .
Offline
Aug 24, 2009, 11:08 AM
#41
First off. Don't trip!  even if the cel light comes on it's really no big deal it just sucks if it's on for another reason and you don't know cause your header. As everyont has commented. The header eliminates the PRE-CAT and this is why it throws a code. There are diff ways to try and get it off rrm sells the eliminator but that didn't work for me and I'm to lazy to grind it down... It still throws a code with the eliminator, however you can mess with and get it not to.
Also if it's rusted you bought it used. No biggie man. Still good most likely.
As for legality. It s technically illegal I suppose... Which is bull **** cause I run just as clean emissions wise... This is for CA. Idk where you are located... So idk about you
bit for me you really just have to take it off and but tthe stock manifold back on wen you get t smogged.. No one is going to pull you over and be like is that a header ?! Omg you going to jail !! lol so don't trip sounds like you got a good deal and have fun with a couple extra horses!
Offline
Aug 24, 2009, 12:43 PM
#42
Oops.  LoL.
I guess I was tired and frustrated last night because my response was a bit backwards. But what I meant was that the original exhaust parts would be rusty...not the new header I'm getting. I apologize, my fault.
Also, I live up in Washington state and just had my emissions test done without the header. Not sure if it would be a problem in the future though.
*Sigh* Anyone interested in a header for 03-06 lancer
I may just sell the bloody thing so I don't have to worry about any problems.
.....who knew modding would be so difficult.
Offline
Aug 24, 2009, 12:58 PM
#43
modding is not difficult. You can always swap back to the original header in the event of upcoming smog checks. As for rusty exhaust parts, um, so what? A spark plug extender bought from a local auto parts store and installed on your lower o2 sensor will work like a cel eliminator. And as far as legality goes, no one would be doing it if it was a big deal. I was just saying it above as a joke. Install your header and enjoy it. I reccommend removing the radiator fans for the install btw, makes it much easier.
__________________
Offline
Aug 24, 2009, 10:04 PM
#44
dude im a noob.. and a header swap is CAKE! some nuts some bolts and bam new header and extra horses! put it on and i promise you wont regret it
Offline
Aug 24, 2009, 10:34 PM
#45
Our $19 CEL Eliminator will work with OBX. Just install it in the 2nd o2 hole.
ROAD/RACE
__________________
Take two....
[/IMG]
Offline
Tags
02, 2005, cel, code, dc, eliminator, es, headers, lancer, mitsubishi, oxygen, oz, p0135, rally, sensor  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
