Lancer TroubleshootingGet help with any troubleshooting problems you may have.
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Pretty simple question, so i'm assuming a simple answer...
At above 75 miles per hour, the car starts shaking very, very lightly. So lightly that passengers barely notice it, if at all. However the wheel starts to shake pretty badly.
my front end feels like it's going to shake off at about 65-75 mph, steering wheel shakes back and forth as well, but no bend in the rim. what up? i have extreme lancer lean to the driver's side in the front, could it be struts and springs? have already replaced the front lower control arms, front sway bar links, had tires rotated and alighned, and balanced twice till thery are now dead on, changed my plugs too. (thought maybe plugs causing vibration) still I 'm shaking like a branch in a hurricane. NEED HELP
__________________
- Weapon-R Secret Weapon
- OBX R Delete Pipe
- 17 inch Motegi FF7 Gloss Black Wheels
- 215/40/17 Hankook HR II Rubber
- Netami Lowering Springs
- Evo Stereo Relocation Kit
- Clear Reflectors
- Custom Tinted Tails and 3rd light
- Reverse Indiglo Halo Guage Face
- Push Button Starter
- Ralli/////art Radiator/Oil cap
- Razo 340 gram Black Chrome Shift Knob/Pedals
- Reverse Indiglo HVAC Surround
- Borla Muffler
- Red Engine Dress- up silicon hose kit
- The Biggest pair of ***** you've ever seen
yeah. its either an allignment or balance problem. check to see if you have mudd or something on the inside of the wheel. that allways throws mine off in the winter.
it helps me out a lot if you READ MY POST BEFORE MAKING A REPLY... I already had my wheels balanced TWICE they are dead on balanced and had the alignment. the issue is still having the problem. if it was simply solved I never would have asked for HELP. thanx though.
__________________
- OBX R Delete Pipe
- Clear Reflectors
- Borla Muffler
Most tire shops dont spin the tires at 75mph when they are balancing them so they may be perfect when they are balancing them. I have the same problem when I get up to that speed but there is a cure, dont go that fast on the streets. You are not meant to go that fast on public roads and tire shops dont plan for you to so they really dont try to balance them that well because they dont have to.
__________________
Quote:
Originally Posted by SASD209
If lancerman doesn't give a crap, then neither do I . And neither should you. And that's how it is.
Quote:
Originally Posted by GearDownSon
Just reading that grew hair on my *********.
that is the most retarded, inbred, banging your sister while eating a mayonaise sandwich answer i have ever heard. you don't have to balance your wheels with a 75 mph spin. and the cure isn't slow down. I don't drive that fast on the city streets, but on the highyway yes. i have no problem on the city streets, but I drive for a living around 200 miles a day, and most is highyway. Something is wrong with my front end. It may be suspension, tie rods, or steering. but please don't pull stuff out of your **** if you don't know the answer, there is way too much of that on this site already.
__________________
- OBX R Delete Pipe
- Clear Reflectors
- Borla Muffler
Im pretty sure thats just the suspension. I have an es and you have an oz rally so it may be different, but my suspension isnt exactly top of the line. The strange thing for me is that it shakes at around 80 mph, but then feels fine at around 90... go figure
Hey Judgedbyman, if you want an answer then start your own thread and let us all pour saline solution all over you because so far all you have done is prove to us that you are just a giant douche.
If its not a wheel balancing as you have so boldly stated, then F*ckin go get the car looked at. It sounds to me like someone who thinks their car shaking at 75mph is caused by plugs doesnt need to be working on his car in the first place. Go to a shop, have them figure it out, and spare us your headaches and bashing
__________________ EvoM member through 4 generations of Mitsubishis :)
2011 Evolution GSR - Octane Blue
2009 Lancer GTS - Octane Blue - Primarily stock
2003 Lancer OZ Rally - Munich Silver - Custom turbo kit at 7psi
1993 Eclipse GS - Typical 18 year old kid ricer mods :)
Plugs are not reccommended for radial type tires...BTW.
Wheel weights fall off! Having the tire rebalanced once a year is good maintanance for any car you drive. Just like checking your oil everytime you fill up.
hey judged, maybe they were giving the original threadstarter that advice, not you. second, why would you say crap like that to people that are trying to help you out. heres some advice, loosen your lug nuts till they are almost off then drive your 200 miles tomorrow. save everyone some trouble.
now back to the point of the thread. i'd say align and balance. my new wheels were supposed to come balance so i just threw them on. they were really wobbly on the freeway seemed like i was on water, got them balanced and went for an alignment since i just installed springs and now everything is okay.
it could also be tires btw. that happened to me one time, i ate off so much of the tires one time, the front tires were showing the steel braidings. if you have uneven tread, this would be a big factor too.
__________________
For sale: 1300W Sony Xplod 12" Subwoofer - unopened. PM me for price.
