service engine light
Old Jun 16, 2007, 12:47 PM
therzdae's Avatar
So I have seen a few threads around this question, but not one that pin's it... So let me get started
I dont trust mechanic's at all, Every car Ive brought to different mechanics have always came back worse or not fixed at all... So I must do this my self so dont tell me to take it to the shop k thx.
Now to the car... Yesturday I was driving on a on-ramp and my car just stopped accelerating I was going 20 for about 3 minutes with my petal to the metal... after it finally kicked in my "Service engine light" came on... any ideas?
my car is a auto, its at 111k miles, and in about 200 more miles the oil will b at 3000 miles...
Old Jun 16, 2007, 01:02 PM
Orville's Avatar
check 4 vacuum leaks, o2 sensors maybe... there's a start
Old Jun 16, 2007, 01:12 PM
ambystom01's Avatar
Get the code pulled and see what it is. It could be something harmless or it could mean your engine is in a death spiral.
Old Jun 16, 2007, 01:34 PM
therzdae's Avatar
ha death spiral, i get that at autozone right?
Old Jun 16, 2007, 01:44 PM
ambystom01's Avatar
Yep.
Old Jun 16, 2007, 07:53 PM
SLVROZ_03's Avatar
You got it! AutoZone them codes and let us know the bad news...
Old Jun 16, 2007, 08:37 PM
Go2fast's Avatar
Figure out the codes is the start!
Sounds like the Mass Airflow sensor. Mine came off my intake and did a similiar thing. It wouldnt accelerate.
Old Jun 16, 2007, 11:09 PM
therzdae's Avatar
hmm well hopefully they are open on sundays, ill keep yall posted, thanks for the response's
Old Jun 17, 2007, 05:17 AM
Orville's Avatar
yes indeed
Old Jun 19, 2007, 07:51 AM
SLVROZ_03's Avatar
Update?
Old Jun 26, 2007, 01:03 PM
therzdae's Avatar
sorry ha, my computer messed up.. well i messed it up and i couldnt use it for a few days... but now then...
I went by their and they said cylinder 2 misfired, the guy said it could have just been a peice of trash or something that got stuck in the oil(?) or a spark plug misfire... so I rechecked my spark plugs that are only 300 miles old, they are still on the correct measurement... its not doing the problem any more, but im still conserned ... should i be?
Old Jun 26, 2007, 02:20 PM
atilla's Avatar
check your wires. i had a tiny crack in one of my wires and it caused all sorts of misfires. it was so small i never noticed... then it started arcing and i ended up finding it on an inspection of everything after i put on my ported intake manifold.
i got a new wire from leftovers after my friend did a tune-up on his mother's eclipse and that fixed me right up!
Old Jun 26, 2007, 02:30 PM
jakermeister's Avatar
Maybe you didn't plug the cables on hard enough the first time. If it went away I wouldn't worry too much about it.
Old Jun 26, 2007, 02:54 PM
atilla's Avatar
or if you used some silicone to make the boots slide on easier you could have put too much on causing them to slide right off.
Old Jun 26, 2007, 07:29 PM
therzdae's Avatar
the light is still on till this day, and what wires are u talkin about? the spark plug wireS?
