Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Lancer shaking at highspeed
Old Mar 31, 2014, 07:10 PM
Thahomeboyb's Avatar
My 2002 lancer shakes when I go 75 + . Does anyone know why and the fix ?
Old Apr 1, 2014, 08:15 AM
Veronica's Avatar
Need to troubleshoot a bit more...
When it is shaking - put the car in neutral - does it stop shaking?
When it is shaking - lightly depress the brakes - does it stop? If so - now try it with the parking brake (to isolate front from rear brakes)...
Could be:
Tires (balance or cupped)
CV joint/shaft
Engine/tranny mounts
or more... so report back!
Old Apr 1, 2014, 12:04 PM
From experience it starts to stop when I press lightly on the brakes but I'll check when I get on the highway
Old Apr 2, 2014, 07:25 AM
Veronica's Avatar
If so - you may have a warped rotor or bad bearings.
Jack (use jackstands!) and pull/push the wheel (any play?)
Jack and spin the wheel - does the rotor go 'whooshwhooshwhoosh' and you can see the caliper 'pulsing' as it moves against the rotor?
Old Apr 4, 2014, 03:21 AM
Ok so I jacked the car up but the wheel won't spin cause it's fwd so the wheel can knly move a little forward and backwards
Old Apr 7, 2014, 09:42 AM
Veronica's Avatar
With the parking brake on, rear wheels chocked, and the car in neutral - they should spin with only some effort.
Report back!
Old Apr 7, 2014, 09:56 AM
MuslimEvoFreak's Avatar
If the rotors are not warped and it shakes violently when going at higher speeds but decreases as you slow down it is mostly likely your outer tie rods. I had this exact issue on my evo.
Old Apr 7, 2014, 02:25 PM
It's not a violent shakes but it's more like a vibration. And I will check again on Thursday .
Old Apr 20, 2014, 12:18 PM
Hantke's Avatar
Okay, well i had written out a long detailed response, but the website logged me out.
Basically, I have the same issue, and it boiled down to the tires, different tires = no problem, rotations every 200-300 miles (Very impractical, i know) = no problem. I'll hopefully have new tie-rods soon and i'll update on that, but until then i just tap the gas or slow down by 5ish MPH add speed back up, another possible issue is a wheel weight, make sure they are all nice and tight!
Old Apr 20, 2014, 07:59 PM
I do have different tires .
Old Apr 20, 2014, 08:10 PM
VanduzerWilliam's Avatar
Suprised noone has mentioned wheel bearings!
Jack car up again and try to shake wheel left to right.
(ie grab rim, and shake violently with the car properly supported, it will somewhat be like 'if you had a loose lug nut')
if you get any play while doing this replace hub+bearing
febyzaoldyeck1
Nov 25, 2015 09:04 AM
princess33
Sep 14, 2014 08:08 AM
benvprov
Lancer Troubleshooting
10
Dec 9, 2013 07:51 PM
Viegasjuice
Apr 3, 2013 06:36 PM
therzdae
Lancer Engine Tech
17
Jul 21, 2007 10:19 AM
Quick Reply: Lancer shaking at highspeed
