Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Transmission fluid and oil change questions
Old May 9, 2013, 06:12 AM
princess33's Avatar
I have an 09 GTS. I drive it daily and I drive it hard and fast. I bought it used. The dealer has it set to change the oil every 5400 miles, however we have an Eclipse with the same motor and the oil change interval on it is the normal 3 months/3000 miles.
So I'm confused. How often should I be changing the oil?
Also, how often should I change the transmission fluid?
Should the tranny fluid be done by a certified mitsubishi motors mechanic? We only have one Mitsubishi dealer here and their customer service and business practices totally suck!
Old May 23, 2013, 01:34 PM
timereaper's Avatar
6000km on dyno oil 10,000km on synthetic for oil change. transmission fluid at least 48,000km before you change that. No, you don't have to go to dealership to do changes.
Old May 23, 2013, 02:59 PM
Hail to the Beard
Beardly P's Avatar
https://www.mitsubishicars.com/media..._Non_Turbo.pdf
Old May 23, 2013, 03:04 PM
Hail to the Beard
Beardly P's Avatar
Also, just noticed that only under the Severe Maintenance Schedule do you change transmission fluid every 30k miles. It doesn't say to change at all under the Regular Maintenance Schedule, just to check it.
Ghilversumtuner
23
Apr 11, 2019 09:28 PM
Chrushev
Lancer Troubleshooting
Mar 7, 2017 11:32 AM
RA2013
Jun 19, 2015 07:43 AM
glomb23
Aug 2, 2010 12:32 AM
CanadianEvo
13
Aug 13, 2008 08:30 PM
Quick Reply: Transmission fluid and oil change questions
