Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Tranny/Drivetrain Tech
Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 26, 2002, 04:10 AM   #1
Personal Sales Rating: (0)
CRXAudioSound's Avatar
Drives: 89 CRX Si, 02 Lancer OZ
Short Shifter Install
Alright boys n gurls here's a detailed explanation on how to install the B&M shortshifter so you don't have to waste an hour and a half doin it...
1)Remove the two screws from the bottom of the big compartment of the center console
2)Pop center console off (connected by snaps at the front of the console)
3)Pop off small front piece under the glove compartment (connected all by clips)
4)Pop off small front piece under steering wheel (ther's one of those pop screw thingys u need to get out)
5)Behind the front pieces on both sides there is a pop screw thingy on each side -- push the middle to pop them out
6)Pull front center console out (the shifter should be exposed)
The rest of the install can be done with the instructions provided with the shifter -- they're pretty detailed...here are some tips though:
-The pivot cups were freakin hard for me to pop off...I spent like 30 mins on both of them...your best bet is to use a wrench and cover the cup with a tshirt and try to pop it off with the wrench
-Remember how the shifter spring sits on the shifter...took me a while to put it in right
-Use rediculous amounts of grease...I greased it up so much that when I put the cup back on a buncha grease flew everywhere cuz I used so much...that's definitely the way to go =)
-Grease the big pivot ball in the middle of the shifter...the instructions dont say to but its a good idea...I did it
-Get a non-metallic shift knob...the summer heat is a killer and you'll burn your hand on a hot sunny afternoon...I jes drive with a tshirt over my shift knob...ghetto eh?
I think that's about it...hope this makes all your installs easier then mines
Offline
Old Jan 11, 2003, 06:21 AM   #2
Personal Sales Rating: (1)
agsmooth84's Avatar
Drives: 2000 Cadillac Catera Sport
Send a message via AIM to agsmooth84
very useful but that kinda makes me not want to attempt this on my own.....im scared
__________________
"I don't care how fast it is, I would never get a car called neon. It might as well be called the Dodge Pink Elephant."
Offline
Old Jan 11, 2003, 06:26 AM   #3
EvoM Administrator
Personal Sales Rating: (8)
HobieKopek's Avatar
Drives: A little red Neon. I also have a Lancer that presumably still rolls...but doesn't drive.
Send a message via AIM to HobieKopek
Quote:
It's not as hard as it sounds. Should take anywhere from 45-90 minutes if you know how to follow directions and turn a wrench.
__________________
Quote:
Originally Posted by Foggy View Post
I believe the bears are our future
Feed them well, and let them lead the way...
Quote:
Originally Posted by Raphael
Hi. As you can see I'm a bear. I contain no artificial flavors and no artificial colors. Now you may be thinking, "Oh, he's such a cute little bear," but let me tell you I am hard. Really hard. Deep down, I am still a bear. An animal born to raise hell. If I saw a dinosaur right now I'd rip his head off.
Sign up to win prizes by running web searches with Blingo. Powered by Yahoo!
Offline
Old Jan 11, 2003, 11:11 AM   #4
agsmooth84's Avatar
ye the following directions is the tricky part
__________________
Offline
Old Jan 13, 2003, 01:23 AM   #5
Drives: 2002 Lancer OZ
Send a message via AIM to rhitme03
Did mine last Thursday... hardest part is separating the shifter ball from the socket... Use the kitchen counter or equivalent... Rest the socket on the edge, and apply firm pressure by pulling down on the shifter... When you hear the pop, look where the socket flies... and recover it...
I also did the bushings at the same time... Definately worth the extra time and the few $$'s on the install... Shifts now feel shorter, more precise, and there is a mechanical feel to them...
__________________
Remote Start On a Manual... YES... It can be done... It even won't start while in gear!
Offline
Old Jan 19, 2003, 10:22 AM   #6
I also got the B&M short shifter.... it's easy for me to get 2nd gear scratches (car is modified) every time now and the shifting is much quicker... with no time wasted between gears.. Hardest part for me was getting the center console out.
__________________
Yellow '03 OZ Rally
Offline
Old Jan 19, 2003, 10:31 AM   #7
jon_e_blaze's Avatar
Drives: '02 O-Z Rally
Send a message via AIM to jon_e_blaze
doesn't sound so bad, think i'll install myself when i get one, thanks for the info
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
