First off, welcome to the forums. I think you're a bit confused. The Lancer has a 2.0L SOHC 4-cylinder 4G94 engine. It is a 2.0L, not a 4.0L. I believe the ACT clutch kits should come with a clutch disc, pressure plate, clutch alignment tool and throwout bearing. You should give ACT a call or shoot them an email to verify, but ANY "clutch kit" should come with all of those components. Also, make sure that the clutch kit is for a 02-03 Lancer. The slave cylinder and throwout bearing design was different from 04-06.
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
