Sep 1, 2009, 06:52 PM
Personal Sales Rating: ( 0)
1992 Eagle Talon
Drives: 92 eagle talon
Automatic Transmission Filter
Has anyone on here actually changed the transmission filter on their auto lancer? Im working on an 03 OZ and have flushed the system. Now I took the trans pan off which is actually on the front and theirs no filter. The gasket that came with my filter matches the pan, but behind the pan is mechanical parts of the trans. Im going to look at it more and see just what Im supposed to do here, but I highly doubt I should take those parts off.
Any one with any actual experience doing this please share some insite. I have a long drive this weekend and want the car in good order.
Thanks,
-Colton
Offline
Sep 1, 2009, 09:34 PM
Personal Sales Rating: ( 13)
2002 Mitsubishi Lancer
Drives: A b00st3d 2002 Lancer OZ
For our cars there is no replacable filter. There is a screen near the middle of the transmission but you wont get to that unless you take it apart.
So, short and sweet. No, there is no filter to be "replaced" during regular maitenence.
Offline
Sep 3, 2009, 07:45 PM
1992 Eagle Talon
Thank you for that. I went ahead and returned the filter, and after the flush the car now slips into 3rd gear...Don't know whats going on their. Used appropriate fluid and volume. Hop it goes away I guess.
Offline
Sep 10, 2009, 01:50 PM
Drives: 04 Lancer OZ
car shouldnt slip after just changing the oil, regardless if you took th epan off or not. what type of trans oil did you use?
Offline
Sep 11, 2009, 07:23 PM
1992 Eagle Talon
I used the directions someone posted on here about flushing the transmission. I even had the pan off so figured I'd for sure need the 5 quarts that were said to be put in. After 5 quarts in the car was about 1 quart or more over filled. So that was why it slipped, it was overfilled, I drained it out and eventually got it just right. Then had to reset (unplug the battery) to get the trans to shift correctly. These cars are funny like that, TCU seems to learn its way and keep it. Now its all good though. Took a lot of work getting the car to operating temp. Get it level and check fluid, drain some, check level etc. My garage is sloped..maybe thats the real problem.
Offline
Tags
02, 2002, 4g93, atf, change, eagle, filter, flush, home, lancer, located, location, mitsubishi, pan, slip, talon, tranny, trans, transmission  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
