Jun 14, 2009, 12:08 PM
Personal Sales Rating: ( 0)
Drives: 2002 Lancer OZ Rally, 2000 Kawasaki Ninja ZX9R
Slave cylinder swap
Whats up guys? I just bought a stage three clutch for a mirage and Ive been told the throwout bearing only works with 04 up which I knew at the time of buying. I was curious if its possible to swap the slave cylinder and shifting fork from the 04 up onto my 02 transmission? I would like to do this for several reasons, one being it would be easier and cheaper to replace the throwout bearing. Two, because I dont have 140 bucks to replace my current throwout bearing. I dont know how smart it would be to reuse my old one as it has 140k on it, which doesnt seem like a bright idea to reuse. I just want to know if the 02 transmission has all the same mounts as the 04 up so that I could get a slave cylinder and shift fork or if Im up $hit creek for this? Thanks to all.
__________________
Drives a Lancer, nuff said.
Quote:
Originally Posted by rpm_ruffryders
Let those that think outside the box do what REAL TUNERS do best...and thats find new ways to keep the lifestyle/scene that you're in ALIVE.
Offline
Jun 14, 2009, 12:56 PM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
Yes you can swap your slave cylinder over to the 04+ external style. I've got all the parts laying around to do this when I get my transmission back from rebuild.
Offline
Jun 14, 2009, 02:18 PM
What are all the parts necessary to do this and will mirage parts work cause I know the 4g93 tranny is supposed to be the exact same housing and the slave cylinders look identical and I can pick those parts up for alot cheaper.
__________________
Offline
Jun 14, 2009, 03:20 PM
MD747524 Clutch fork Mirage = yes
MD747413 Boot Mirage = yes
MD719602 Fulcrum Mirage = yes
MD747279 Bearing retainer Mirage = yes
MF140203 Bolt (x4) Mirage = yes
MD749998 Throwout bearing Mirage = yes
MD748038 Clutch line Mirage = no
MR980563 Slave cylinder kit Mirage = yes
MF241255 Bolt (x2) Mirage = yes
MD706185 Throwout bearing clip Mirage = yes
So as you can see, with the exception of the clutch line that goes to the slave cylinder everything is compatible with parts from the 1.8L Mirage
Offline
Jun 14, 2009, 11:27 PM
Oh wow. Thank you senate. I dont often get information that is this detailed. I appreciate that you do your homework. Thank you again.
__________________
Offline
Jun 15, 2009, 05:35 PM
Quote:
Took me like 5 minutes to select all the parts in MitsuCAPS in my XP VM and copy them into the post, but you're welcome anyway.
Offline
Jun 15, 2009, 06:31 PM
How much did you spend for all your parts for this swap?
__________________
Offline
Jun 15, 2009, 07:07 PM
Personal Sales Rating: ( 2)
2002 Mitsubishi Lancer
Drives: 02 lancer oz 74/76/79 Corvettes
How much do all those cost the the throw out and slave are the same part for the 02. And was like 120 from dealer. Was all those parts cheaper?
__________________
Budget Turbo :P installed Custom Borla cat back 2.5,Fidanza flywheel, Act xtss, 4g93 intake, injectors 275cc, Auto meter Gauges, Injen CAI,High flow Cat,aeromotive 1:1 fpr, Walbro 255, circle earth ground
on hand 16g6 with 10.5 hotside,Ported&polished head,Megan Racing 3" downpipe, Intercooler and piping, Greddy BOV rs, guage pods, gates racing belt, Forge wastegate with spring, tactrix cables, 16g manifold, oil feed
Needs injectors
Offline
Jun 15, 2009, 07:35 PM
My dealer wants 140 for an oem. I dont even care if it costs more. It saves you a ton of money in the long run but just curious since I dont have much cash. Ill probably end up putting my old one back in till I can save the money up and hope it doesnt go out
__________________
Offline
Tags
02, 2002, 2003, clutch, cylinder, evo, lancer, line, oz, rally, replace, replacement, slave  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
