Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Tranny/Drivetrain Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 11, 2009, 11:25 AM   #1
Personal Sales Rating: (0)
s84kam's Avatar
Drives: 09 WW Sportback
Manual transmission - downshifting / Heal and toe rev matching
I've been driving manual for years and i've only tried the heal and toe only when i try to drift a rear wheel car. For all the times i've been driving i've always used my downshift to slow down. I'm hearing too many mixed answers. Out of curiosity I just want to ask if any of you guys actually use the heal and toe technique to slow down or just using your breaks?
Using the tranny to downshift, does this cause any premature wear of any sort?
Offline
Old Jun 11, 2009, 11:45 AM   #2
MasterAK's Avatar
Drives: 08 Lancer ES MT
Heal and toe implies the usage of the brakes so you actually use the brakes to slow down before entering a corner while rev matching at the same time.
__________________
2008 Electric Blue Lancer - 5 spd
☑ Works Rear Sway Bar
☑ HKS Drop-In Filter
☑ 17x8 Rota DPT / Falken FK-452
☑ Rally Armor Basic Mud Flaps
☑ 20% Tint
☑ DDM SlimLine 4500K HID with DRL defeat harness
☑ Fog Light Kit
Offline
Old Jun 11, 2009, 12:10 PM   #3
Personal Sales Rating: (7)
2007 Subaru Impreza
ambystom01's Avatar
Drives: Robut bear cavalry to the bearpocalypse
Bingo, heel-toe is somewhat useless around town, rarely do you get into a situation where you need to hammer on the brakes while downshifting at the same time. For the most part, I leave heel-toe for the track and just rev-match around town if I need to downshift. Using the tranny to brake is a bit silly, brake pads are cheaper than transmissions.
__________________
This FAQ is a great starting point for new lancer owners
If you want my help, PM me, I won't post in technical forums lest I make waves.
Offline
Old Jun 11, 2009, 12:16 PM   #4
Greedy_son's Avatar
Drives: 09 Lancer GT
Dont think downshifting will cause premature wear. If you do it properly (match your speed to gear ratio) its safe and wont cause any damage while saving your brakes, now if you downshift from 5th gear to 3rd this will cause some damage .
__________________
09 GG GT Lancer
Apexcone 6000K HID
Evo X CF hood
RRM CF diffuser
18 Tenzo M1 w/ HTZ III
Ingalls Camber Kit
Rays Lugnuts
Eibach Sportline
Ralliart Tails
Sparco Shifter
VG Shark fin
30% Solarguard tint
Pioneer 700bt w/ Siruis
Lamin-X Headlight tint
Offline
Old Jun 11, 2009, 12:20 PM   #5
2007 Subaru Impreza
ambystom01's Avatar
If you're using the transmission to slow down, it causes a bit of wear. How much is debatable. I'd still rather use the brakes than the transmission unless you have miles upon miles to slow down.
__________________
Offline
Old Jun 11, 2009, 09:53 PM   #6
s84kam's Avatar
yea that sounds about right, brakes are cheaper than transmissions. Gotta keep that in mind if i want my lancer to keep lasting a long time
Offline
Old Jun 11, 2009, 11:16 PM   #7
Drives: 2008 red lancer GTS
i heal toe when downshifting, its a way of rev matching when braking, i realized when i started using heal toe, my downshifts have been signifcantly smoother
__________________
MODS:
Apexi Grounding system
6000K HIDS
Bride Zeta III type S bucket Seat
Takata racing harness
TMW short shifter
08 tein s-techs
Blitz radiator cap
HKS Limited Edition oil cap
RRM V2 SRI with Trust AIRINX air filter
Sprint Booster
Razo Shift Knob
Prodrive GC-10E 18x8.5 +34 offset
Toyo T1R tires 235/40/18
Rays Red extended lug nuts + Valve Stems
Accolade Wide body kit
Greddy TiC
Seibon CF Hood
Seibon FL
Rexpeed Canards
Rexpeed V-style Fender Vents
+ings Z-power GT wing
Offline
Old Jun 11, 2009, 11:23 PM   #8
2004 Mitsubishi Lancer Evolution
My Garage
evoDON's Avatar
Drives: 2004 Mitsubishi Lancer Evolution VIII GSR SSL
Send a message via AIM to evoDON
i just rev match around town. no need to really heel toe. but it does help on the track
__________________
- AMS 2.3L Stroker Kit W/ Oliver Rods
- ETS HTA3582 Twin Scroll Turbo Kit And 3.5" FMIC
- Exedy Twin Metallic Clutch
- AMS 1000HP Fuel System
- AEM EMS (Speed Density)
- Magnus V5 Cast Intake Manifold And BBK 75MM TB
- Brian Crower 280 Cams W/ Valves, Valve Springs and TI Retainers
- HKS Cam Gears
- AF Custom 4" Intake
- HKS Carbon/TI TB
- FIC 1050cc Injectors
- Mishimoto Radiator
- AMS Oil Cooler
- ETS Mini Battery
- HKS SSQ
- Hallman Pro RX Boost Controller
Applied Force
Offline
Old Jun 12, 2009, 05:28 AM   #9
Personal Sales Rating: (1)
Drives: 2008 Grey Lancer GTS (5spd)
Send a message via AIM to kalpakiotis
the only extra wear downshifting will cause is to your clutch plate. The gears are all high grade steel and as long as your not mashing into the gears you should never have any real problems with it. It's debatable on how much wear it'll cause, but I don't care that much about it since I plan on replacing it with something better in the future.
Offline
Old Jul 16, 2009, 08:32 PM   #10
djslik408's Avatar
Drives: 2005 Evo & 2008 Lancer GTS
Send a message via AIM to djslik408
Still brake pads cost a lot cheaper.
Offline
Old Jul 17, 2009, 07:42 PM   #11
2008 Mitsubishi Lancer
SirLancerlotWPG's Avatar
Drives: 2008 Mitsubishi Lancer GTS
Quote:
And alot easier to replace yourself.
Offline
Old Jul 20, 2009, 02:57 PM   #12
LanceHer's Avatar
Drives: 2009 Lancer GTS
How the heck do you guys heel-toe in this car?! The pedals are too small in my opinion or just too wide apart.
I have tried many times but to me it seems the gas pedal is too low, and i really have to jam on the brakes to get the heel to blip the gas.
It only works perfectly for me when i am wearing an old pair of wide shoes. But this is stupid because sometimes i catch the brake with the shoe edge while pushing in the clutch with the left.
Did any of you put a pedal cover on the gas to give it a little height?
__________________
Lancer fan since 1973
Offline
Old Jul 20, 2009, 09:54 PM   #13
Drives: the Batmobile
well even though its called heel-toe
u dont actually use ur heel. its more like the lower right side of ur foot. and the ball of ur same foot to apply pressure on ur brakes.
and no i didnt give my gas pedal any height, its just practice its a bit different on every car right. u probably just need to tilt ur foot a bit more to the right and blip ur throttle a bit harder
__________________
2009 Tarmac Black Pearl Lancer SE...5sp MT
Offline
Old Jul 21, 2009, 08:47 AM   #14
2007 Subaru Impreza
ambystom01's Avatar
It depends on the person, I very much use my actual heel. Try moving your foot higher up on the brake pedal.
__________________
Offline
Old Jul 21, 2009, 10:46 PM   #15
djslik408's Avatar
Sooooo heel toe huh. It seems that a couple of people have different definition of it.
Offline
Tags
corvette, downshift, downshifting, evo, heel, manual, match, matching, rev, revmatching, shifting, sounds, toe, transmission, transmissions, viii
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
