Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Tranny/Drivetrain Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 19, 2009, 10:57 PM   #1
Personal Sales Rating: (1)
kronic420haze's Avatar
Drives: 2003 Lancer
Send a message via AIM to kronic420haze
help with clutch install question
http://forums.evolutionm.net/members...cture-041.html im puttin in a clutch in a 03 ES and i wanted to know how you take out the cup the the axle shaft goes into on the transmission side. does it pry out or does it come out when you seperate the tranny from the engine. see if you can make out the pic... also i wanted to know how to bleed the clutch? do i loosen the nipple on it and pump the clutch like im doin brakes? i got royal purple syncromesh tranny fluid. is that the right stuff. i used amsoil last time but heard royal purple is better. one more question what kinda brake/clutch fluid do i use?
Offline
Old May 20, 2009, 05:56 AM   #2
Personal Sales Rating: (7)
blaze_125's Avatar
Drives: Yellow OZ
Wtf happened to your axle?
You should be able to pry it out. Get a pry bar between the trans housing and "what's left of your axle" and it will pop right out.
To bleed the clutch... you are right, you bleed it as you would bleed your brakes.
Fluid? I like the Ford stuff. If you track your car very hard, go with DOT 4 fluid. If it's a daily driver, stick to DOT 3.
Trans Fluid... find my trans fluid thread(sticky at the top) and read the bottle in my pictures. I'm too lazy to do it this morning.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Old May 20, 2009, 01:34 PM   #3
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
Yea, dude. You just separated the CV on your axle. Are you going to buy a new axle or just pack it with grease and hope for the best?
Offline
Old May 20, 2009, 07:05 PM   #4
Personal Sales Rating: (0)
Drives: 2004 ES
Ha, he must have tried pulling on the shaft to get the axle out. At this point you might as well leave it, you should be able to pull the trans with the inner joint still attached. Then with the trans out and on the floor you get pry it out. Better start checking parts stores for a new axle! That one's not going back together.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
