Feb 24, 2009, 09:08 AM
Personal Sales Rating: ( 1)
Drives: 2002 Mits lancer, 1990 Eagle Talon TSI AWD
No clucth
I was driving my lancer to Baltimore yesterday when all of a sudden I pushed in the clutch and it went to the floor. At first I thought the slave cylinder was gone, but after sitting on the side of the road for a few minutes my pedal was working again. So I turned around and went back home. On the way home I lost the clutch again and it popped out of gear. It continued to do this until I got home. Once I made it home I couldn’t put it in gear. After I few minutes I was able to put the car in gear but it was hard as hell. So my question is do you guys think it’s the clutch or the tranny.
There was also a funny sound coming from the tranny. I called the trannny shop were I had my clutch replaced and they said that it might just be the slave cylinder and a bearing. The car has 192,000 miles and he clutch was replaced 30 thousand miles ago.
Offline
Feb 24, 2009, 09:47 AM
Personal Sales Rating: ( 0)
Drives: TurboCharged Mitsubishi Lancer OZ-Rally
Try checking your brake fluid to see if its low. If it is low try putting more brake fluid in and bleeding the clutch. That should help it last for a lil while longer.
__________________
pushing the limits of my stock 4g94 (turbo'd)
Offline
Feb 24, 2009, 01:54 PM
I tried that yesterday. I think its seen its day!! I'm checking on a new tranny. I will know more once i pull the trans on Friday.
Offline
Feb 24, 2009, 04:24 PM
Drives: 2004 ES
It's either the master cylinder, slave cylinder, or the lines. Probably not the lines unless you've replaced them with something non-factory.
Offline
Feb 24, 2009, 06:36 PM
I'm thinking the slave cylinder, but i have to wait until friday. Does anyone know were i can get just the slave cylinder
Offline
Feb 24, 2009, 08:56 PM
Is the 2002 transmission the same as the 2006 lancer? If it is than here is the link for just the clutch slave cylinder. I'm thinking its the same someone correct if i am wrong.
http://www.partsgeek.com/catalog/200..._cylinder.html
__________________
Offline
Feb 25, 2009, 06:32 AM
Personal Sales Rating: ( 7)
Drives: Yellow OZ
 is what you are looking for.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Feb 25, 2009, 06:47 AM
Yeah its looks like to one in the picture sent from Blaze 125. I think there might be a difference in the trannys
Offline
Feb 25, 2009, 06:51 AM
I just checked the part numbers and they are both the same, so and 06 slave cylinder will work in a 02
Offline
Feb 25, 2009, 09:40 AM
I thought so. Hope all goes well.
__________________
Offline
Feb 26, 2009, 06:40 AM
Drives: Yellow OZ
If you do the replacement your self consider this tip:
Don't put the used Salve Cylinder assembly on anything that has any value. There will be fluid leaking out of it and it will RUIN, eat through whatever it leaks onto. Learn from other people's mistakes lol
__________________
Offline
Feb 26, 2009, 10:55 AM
Thanks for the tip Will do
Offline
Feb 27, 2009, 03:39 PM
what is this?
Does anyone have a clue what this rubber thing on top of the tranny. It looks torn on my car. i Think it might be part of my problem
Offline
Feb 27, 2009, 03:41 PM
The first pic is the way i found it and the last pic is the way i think it should look
Offline
Mar 26, 2009, 11:37 PM
Drives: 03 Lancer Oz RMR Edition
Do the 03's oz have a pilot bearing or a bushing?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
