Feb 1, 2009, 09:05 AM
Personal Sales Rating: ( 0)
Drives: 03 lancer
2003 Auto Tranny Insanity
My Lancer has 112k miles and has been a great car but the transmission is possesed. It will shift very rough and get progressivly worse as you drive it. It will shift so hard, it feels like you are being hit from behind. If I let it go, I''m afraid it''s going to break a motor mount.
If I pop the battery off and then reconnect so the ECU resets, it will drive like a brand new car and shift smooth as silk for maybe a day or 2. Then is will slowly start shifting rough again but very slightly and get worse, the more you drive it. The longer you drive it, the worse it gets. I have to pop the batter every 2 days or so to keep it driving smooth. I took it to the stealership and they charged me 200 bucks to change the fluid and re-flash the TCU but it still does it. The tech said he has never seen this before. Since it drives so smooth after a reset it can''t be mechanical, right? Has anyone ever seen this? Does the main ECU control shifting? The car is totally stock with no mods.
Offline
Feb 1, 2009, 09:32 AM
Drives: TurboCharged Mitsubishi Lancer OZ-Rally
Did the people at the dealership check for any bad mounts? Could be numerous of things. Don't just think the only issue lies with the ECU. Sounds like it could just be a worn tranny. Did they check for normal fluids?
__________________
pushing the limits of my stock 4g94 (turbo'd)
Offline
Feb 1, 2009, 07:47 PM
Personal Sales Rating: ( 1)
Drives: Cali into the arms of S6
I had this same problem, your best bet is going to be to put some seafoam in the tranny, and drive for a couple of days, then change it yourself. I don't think it's a bad mount, but mine still does it but it's not as bad, but it's only going into 3rd gear. Try what I said though and when you're checking it SMELL for burnt oil.
__________________
RAPTOR JESUS' ANGEL OF DEATH
WINNAR OF JEHUTY OF THE YEAR AWARD
Quote:
Originally Posted by 22stars
i <3 Jehuty
Quote:
Originally Posted by mikesevo8
:walks in, looks around:
:grabs piece of chalk and writes "Jehuty>VincentX" on the wall:
:walks out:
Quote:
Originally Posted by Kurt
Something is not right about you. I like that.
Quote:
Originally Posted by thetox
shoot a load in her dumper or her belly will get plumper.
XBOX LIVE: TheMasterQweeph (XBOX live made me change my name....sigh)
Offline
Feb 3, 2009, 05:55 PM
Drives: 03 lancer
Yes, the dealer tech said I needed tranny flush since it has over 100k miles, so they pumped it out and refilled it. He said my old fluid looked fine. Strange that he was a dealership tech and said he has never seen this issue before. The motor mounts look good but it is bizzare that it shifts so smooth during driving for an entire day after an ecu reset. The next time the car is shut off, then started again it will get a little worse, then much worse each time it shuts off and restarted until it gets so bad it becomes undriveable.
It almost feels like the gear is shifting up then down, then up again but very fast, like it can't decide which gear it wants to go in or the command that is telling it to shift is stuttering.
If anyone has any ideas please post. Im going to try a different dealership and see if they can help.
I appreciate the feedback!
Offline
Feb 4, 2009, 11:28 PM
Personal Sales Rating: ( 2)
2002 Mitsubishi Lancer
Drives: 02 lancer oz 74/76/79 Corvettes
Being that the car will shift fine at first and as it learn's it Progressively goes down hill I would say that Mechanically/Hydraulically you are fine. Do you notice the problem at a certain RPM or point? Does the problem happen at different RPM and intensity according to throttle position?
__________________
Budget Turbo :P installed Custom Borla cat back 2.5,Fidanza flywheel, Act xtss, 4g93 intake, injectors 275cc, Auto meter Gauges, Injen CAI,High flow Cat,aeromotive 1:1 fpr, Walbro 255, circle earth ground
on hand 16g6 with 10.5 hotside,Ported&polished head,Megan Racing 3" downpipe, Intercooler and piping, Greddy BOV rs, guage pods, gates racing belt, Forge wastegate with spring, tactrix cables, 16g manifold, oil feed
Needs injectors
Offline
Feb 10, 2009, 11:13 PM
Personal Sales Rating: ( 13)
Drives: A b00st3d 2002 Lancer OZ
My car is doing the exact same thing!
Offline
Feb 12, 2009, 05:42 PM
Drives: 03 lancer
No, it seems to shift at the correct rpm's up and down. I am trying to find a used ECU since I have heard the PCM ( the dealership caled it a PCM, powertrain control module) is actually located in the ECU under the center console.
I have done some more testing with it and can do a reset (I pull the battery positive cable, turn the key to ON to drain and power, then turn back off and reconnect battery) and after a reset, it will shift all the way up and all the way down, even manually with the D2, d3, etc. and it is as smooth as silk. Honestly it drives like a brand new car for about a day, or 20 or so miles. Then if shifts with a jerk, but very slight, then gets worse and worse as you drive.
I let it go for 4 days straight and when it shifts at a high rpm, it will actually sqeaul the tires when it shifts. My son thinks its cool. I'm scared it will break a motor mount or one of the cv joints.
It has to be the computer....
Im going this weekend to find a used ECU.
I'll post more once I swap it out.
Offline
Feb 12, 2009, 06:08 PM
That's the conclusion I'm coming to also. But On the other hand it just doesnt make since that all of a sudden something in the ECU would go bad. I'm modded and my tranny is doing the same thing youre unmodded and doing the same thing.
There has to be some common condition. I took it to a tranny shop and the guy there there shot me some bull**** and said my problem is "internal". I asked him Why does he think that and he said it could be a number of things and passed me a quote the whole time I was thinking "then how come is it when I reset my ECU the problem goes away?"
As some advice when you're driving and your car goes to shift before the shift take your foot off the throttle and the shift will not as be as hard but there will still be that knock.
If you happen to come up with a solution be sure to let us know.
Offline
Feb 14, 2009, 03:01 AM
Nobody listened to me.....lol.
I HAD this problem and it went away after the seafoam. You guys have to realize that 80% of the time when you take it to a dealership all they do is unplug and plug the battery and just reset the ECU. Try changing the fluid yourself, when I did it I had some dirt come out. Do this guys when your car is cold feel the shifting is it AS bad? Or is it worse when the car is warmed up?
__________________
i <3 Jehuty
:walks out:
Offline
Feb 16, 2009, 01:19 AM
Drives: 2002 Mitsu Lancer OZ Rally
well i have that problem too but it threw up a code for Solenoids electrical malfunction.. the Service engine soon light came on.. I had some problems with the solenoids inside the tranny.. the guy at the tranny shop just replace them and now it shifts like new.. maybe the guy at the tranny shop GREEN BANDIT went its correct cause me too the shift was like being hit from behind I disconnected the battery and connected it when good for about a day until it did the same thing.. I just leaved the problem thought it could fixed by itself but the rough shifting became more constant.. Im not sure if this is even as close as what its happening to you but it can give you an idea..
__________________
2002 OZ Lancer
Offline
Feb 16, 2009, 01:20 AM
Quote:
it's all good. How much was that?
it was about $300 bucks..
__________________
2002 OZ Lancer
Offline
Feb 16, 2009, 05:06 AM
__________________
i <3 Jehuty
:walks out:
Offline
Feb 19, 2009, 11:07 AM
I think I'll give the Seafoam and a flush a try.
On a side note I think the hard shifting happends when its cold and gets lighter when the car warms up.
But one thing still confuses me. Why the hell would an ECU reset make it go away but eventually come back? And why would that make the tranny start beating itself up?
Offline
Feb 25, 2009, 08:22 PM
That's why it's related to the solenoid, if it was something wrong with the transmission itself the problem would be there no matter what you do.
__________________
i <3 Jehuty
:walks out:
Offline
Mar 5, 2009, 10:33 PM
so is it better now?? any updates
__________________
2002 OZ Lancer
Offline
Tags
2003, auto, cvt, ecm, insanity, lancer, lubegard, patent, reset, shift, shock, solenoid, solenoids, timeframe, tranny, transmission, work  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
