Jan 18, 2009, 01:19 PM
Personal Sales Rating: ( 13)
Drives: RWD EVO & 09 Lancer GTS
ralliart tranny onto oz or es engine
anyone know if it has the same bolt pattern to bolt onto the oz or es engines?
thanks.
Online
Jan 18, 2009, 01:54 PM
Personal Sales Rating: ( 7)
2007 Subaru Impreza
Drives: Robut bear cavalry to the bearpocalypse
Don't think so.
Online
Jan 18, 2009, 02:07 PM
Personal Sales Rating: ( 1)
Drives: Cali into the arms of S6
No it doesn't.
__________________
RAPTOR JESUS' ANGEL OF DEATH
WINNAR OF JEHUTY OF THE YEAR AWARD
Quote:
Originally Posted by 22stars
i <3 Jehuty
Quote:
Originally Posted by mikesevo8
:walks in, looks around:
:grabs piece of chalk and writes "Jehuty>VincentX" on the wall:
:walks out:
Quote:
Originally Posted by Kurt
Something is not right about you. I like that.
Quote:
Originally Posted by thetox
shoot a load in her dumper or her belly will get plumper.
XBOX LIVE: TheMasterQweeph (XBOX live made me change my name....sigh)
Offline
Jan 18, 2009, 05:53 PM
Drives: 03 Mitsubishi Lancer Oz Rally, 04 Mitsubishi Lancer ES
I've heard its basicly the same transmission only with a different bellhousing and gears. It may work if you use your 4g94 bellhousing. You may have to use ralliart axles.
Offline
Jan 18, 2009, 06:58 PM
I'm trying to find out if a 98 1.8 liter mirage tranny fits, and then if i do that if i can still do everything the same on the G64 swap.
__________________
i <3 Jehuty
:walks out:
Offline
Jan 18, 2009, 07:01 PM
Thanks for the info guys, I found it strange the dealer doesn't have different part numbers for them.
Online
Jan 18, 2009, 07:36 PM
Quote:
As far as I know, the transmission is the same, just different gearing. You may not have to go as far on the g64 swap as the other guy did. You might, and should, just be able to use 4g69 axles and not open up the transmission and change out the gears.
Offline
Jan 20, 2009, 07:07 AM
Quote:
I don't mind the opening up process because I know transmission people who can do that. I just...want to know if the mirage will work. Now when you say "different gearing" what do you mean? Different RPM bands? Or you mean just the gears on the inside are different?
__________________
i <3 Jehuty
:walks out:
Offline
Jan 20, 2009, 10:46 AM
The gearing is different, I guess that means rpm bands.
Offline
Jan 20, 2009, 11:33 AM
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
I believe the ralliart has the same gear ratio as the EVO VIII
Online
Jan 21, 2009, 06:05 AM
I would recommend OP to go my route and check on the mirage tranny before looking at the ralliart tranny. Just my .02
__________________
i <3 Jehuty
:walks out:
Offline
Jan 21, 2009, 09:07 PM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
The 4G69 transmission uses an intermediate shaft whereas the 4G94 transmission does not. Only the driver side axle will work.
Offline
Tags
2002, 4g69, axles, engine, es, kit, lancer, mitsubishi, motor, oz, put, ralliart, rally, swap, tranny, transmission  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
