Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Tranny/Drivetrain Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 30, 2008, 08:09 PM   #1
Personal Sales Rating: (1)
texaspete108's Avatar
Drives: 2005 Lancer OZ Rally
Send a message via AIM to texaspete108
Help! After trans swap problems
So here's a list of problems I've encountered since I finished my trans swap last Saturday.
-Keys stuck in the ignition
-Cigarette lighter doesn't work
-After I rev the rpms, when they come back down to 1000, my headlights and my instrument gauge lights dim out for just a second
-Service Engine Soon light is on (I had it diagnosed and nothing came up but light is still on, nothing noticeable stands out as to why it is still on)
-When my car is idling, the rpms rest at 1000 for a few seconds then they move around a bit (give or take 200 either way).
-When driving, my car is abnormally jerky (we have narrowed this down to clearly being because of the motor mounts, any suggestions as to a good set of urethane ones???)
Other than these things, everything else with the swap has gone perfectly. If you have any suggestions how to fix any of these problems please let me know! Thanks
Offline
Old Nov 30, 2008, 08:16 PM   #2
One more thing, anyone know where I can get my sparco seats reupholstered?
Offline
Old Dec 1, 2008, 10:09 AM   #3
bcollinstex's Avatar
Drives: 2002 Lancer OZ
Check your fuses.
Check your grounding points
May be related to a grounding issue.
RRM makes solid mounts. Otherwise, there are no other options for us except for DIY urethanes.
That's all I can think of, just double check wires, splices, etc, and check fuses.
Offline
Old Dec 2, 2008, 01:55 PM   #4
Service engine soon light has gone off by itself. Cigarette lighter is working now. My car seems to have resolved its problem with the rpms while idling. The only thing I still have to fix is the keys being stuck in the ignition.
Offline
Old Dec 2, 2008, 08:06 PM   #5
Juan Martinez's Avatar
Drives: 03 Mitsubishi Lancer Oz Rally, 04 Mitsubishi Lancer ES
Send a message via Yahoo to Juan Martinez
-Keys stuck in the ignition. I had this problem on my 3g Mirage/Lancer. Dealer fixed that. Wasn't due to a swap. Check starter hookups
-After I rev the rpms, when they come back down to 1000, my headlights and my instrument gauge lights dim out for just a second. Your ecu probably has to relearn its idle. There might be an idle control you have to put on yours now that you've done the swap.
-When my car is idling, the rpms rest at 1000 for a few seconds then they move around a bit (give or take 200 either way). Mines like that. Mine usually idles at 1000 to 1200 at start then back down to 800. Depends on which cluster I use. The evo cluster says it idles at 2000 at start then to 1500
-When driving, my car is abnormally jerky (we have narrowed this down to clearly being because of the motor mounts, any suggestions as to a good set of urethane ones???) Depends on how bad the mounts condition are. I could be due to axles. The manual trans takes different axles I think. Alingment or something when you took out the axles might not be tight.
__________________
Build Thread http://forums.evolutionm.net/lancer-...ld-thread.html
Check out my rides at
http://www.cardomain.com/id/k_dog007
03 Lancer OZ Rally
04 Lancer ES
98 Eclipse RS (Traded in July 2007 for 04 Lancer)
01 Mirage ES (Traded in on Eclipse in 2005)
85 Pontiac Fiero (never made it on the road, sold 2004)
93 Eagle Summit ES (Traded in in July 2003 for 01 Mirage)
Offline
Old Dec 2, 2008, 09:03 PM   #6
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
I fully agree with bcollinstex in that many of your issues may be resolved by checking, cleaning and re-securing all the grounding points in the engine bay. Especially the larger gauge ground wire that sits on the bolt securing the bellhousing to block.
Offline
Old Dec 5, 2008, 09:48 AM   #7
Alright I got most of those problems resolved. I have noticed a fairly loud woooing sound coming from under the hood. I think it might be the axles (I used the ones from my automatic trans because the manual ones were slightly worn). Anyone have any insight on this?
Offline
Old Dec 14, 2008, 08:26 AM   #8
I got all those problems solved, thanks for your help
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
