Apr 26, 2008, 11:04 AM
Personal Sales Rating: ( 0)
Drives: 03 lancer oz T
speed sensor issue after 5spd swap
i was wondering is there anyway to wirer the speed sensor up after the swap??? I know there a input and output on the auto and one sensor on the manual. I got the connector for the manual tranny it has 2 wire anyone know which wire to tap that into??
Offline
Apr 26, 2008, 11:40 AM
Personal Sales Rating: ( 1)
Drives: 02 mitsubishi lancer es
try em both, shouldnt hurt anything...
Offline
May 9, 2008, 09:51 AM
come on!!! i know there sum1 out there who did the swap beside me
Offline
May 9, 2008, 11:09 AM
Drives: Lancer ES 2003
Actually, I think its the first time I hear of someone doing it succesfully. Altough, I have not been here for long.
Offline
May 9, 2008, 11:11 AM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
I'm looking over the circuit diagrams trying to figure this out. Its tricky because on the auto models the wire from the output shaft speed sensor goes to the powertrain control module before going to the gauge cluster and on the manual models the vehicle speed sensor goes directly to the gauge cluster. So here is what I have come up with:
Connect the red wire on your harness to the black w/ white stripe wire on your speed sensor harness. For the other wire on your speed sensor, which is black w/ yellow stripe, you will have to connect it to the wire in Pin 80 on the powertrain control module harness. The wire in this pin is also black w/ yellow stripe. It is in the middle row, 3rd pin from the end when looking at the harness going into the powertrain control module. There are three harnesses going into the module. The harness that is 12 pins wide is the correct one this wire is on.
Hook these wires up and you should be golden.
Offline
May 10, 2008, 02:59 PM
Drives: Cali into the arms of S6
So did ^ this idea work?
__________________
RAPTOR JESUS' ANGEL OF DEATH
WINNAR OF JEHUTY OF THE YEAR AWARD
Quote:
Originally Posted by 22stars
i <3 Jehuty
Quote:
Originally Posted by mikesevo8
:walks in, looks around:
:grabs piece of chalk and writes "Jehuty>VincentX" on the wall:
:walks out:
Quote:
Originally Posted by Kurt
Something is not right about you. I like that.
Quote:
Originally Posted by thetox
shoot a load in her dumper or her belly will get plumper.
XBOX LIVE: TheMasterQweeph (XBOX live made me change my name....sigh)
Online
May 10, 2008, 05:38 PM
im on vacation right now so haven't got the chances to do it...be gone for a month i give u the update when i get bak n hopefully get it running...thx for the help
Offline
May 11, 2008, 10:32 AM
ps i have the swap running for couple month now just have no speedometer...
Offline
May 11, 2008, 01:45 PM
Awesome, maybe you could do a write up or something because I really want to do this but I have no idea how much I am looking at. If you could give us a price range that would be cool too.
__________________
i <3 Jehuty
:walks out:
Online
Jul 11, 2008, 09:40 AM
powertrain control module?? u mean the ecu??
Offline
Jul 11, 2008, 10:56 AM
Quote:
No, I mean the PCM. This is used in automatic transmission vehicles. It is like an ECU just for the transmission that governs the valves and shifting. Manual transmission cars do not have these. You need to wire the speed sensor so that it bypasses the PCM (if it is still installed). The instructions I gave are spot on.
Offline
Jul 11, 2008, 04:47 PM
oh would u happen to know where i located?? i look behind the glove compartment couldnt find it
Offline
Jul 11, 2008, 05:13 PM
My mistake. The PCM is the ECU for the auto Lancer. It is located behind the glove box, as you know. Sorry about that. I got lost in the terminology of the circuit diagrams tracing down wires through multiple pages.
Offline
Dec 9, 2008, 11:27 AM
hey senate do u have a diagram of the ecu (the pin out) of the connetor?
Offline
Dec 12, 2008, 02:10 PM
sigh no go on the connection senate
Offline
Tags
02, 2002, 5spd, control, lancer, location, mitsubishi, module, powertrain, sensor, speed, speed sensor issue, swap, transmission swap, vehicle, wire  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
