Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Tranny/Drivetrain Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 24, 2008, 12:47 PM   #1
Silver Sponsor
Personal Sales Rating: (0)
TWM Performance's Avatar
Drives: 84 Rabbit
TWM 2008 Lancer Short Shifter Pre-Order!
Hi Guys,
TWM is pleased to announce that we have recently completed final testing of the 2008 Lancer short shifter, and are now taking pre-orders. We have started our first production run, and we will be able to ship out all pre-orders on May 15th, 2008.
The specs for the short shifter are as follows:
-30% throw reduction
-1.25” shift knob height reduction
-Compatible with stock shift knob or any TWM Weighted Stainless Steel Shift Knob
-Available with optional aluminum shifter base bushings
-Very simple installation, no modification of stock parts required
-Centers shifter in center console, bringing shifter closer to driver for a more comfortable and natural driving position
We have designed the 2008 Lancer short shifter with a reduced shift knob height, as well as a re-positioned pivot point for optimal shift feel and throw reduction. This is a true short shifter, which reduces both shift knob height and angular throw, not just a “chopped off” version of the stock shifter.
The short shifter is fully CNC machined from billet steel and is a complete replacement for the stock shifter shaft. The shifter also features a lifetime warranty as is the case with all of our products. The installation is straight forward and does not require any modification of stock components. Simply remove the stock shifter and replace with the TWM short shifter, typical installation time is approximately 45 minutes to an hour.
The short shifter retails for $149.95 without shifter base bushings, or $169.90 with shifter base bushings.
Until May 15th 2008, we are offering a very special pre-order price of $134.95 without shifter base bushings, or $154.90 with shifter base bushings for a savings of $15.
The optional shifter base bushings provide a more solid contact point between the shift assembly and lower mounting point to remove unwanted flex from the shift assembly. These bushings retail for $24.95 plus shipping when purchased alone, however they can be added for only $19.95 when purchased together with the short shifter.
TWM Performance's weighted stainless steel shift knobs are also all compatible with the short shifter and can be purchased with the short shifter at a $15 discount.
The short shifter is available for pre-order here: 2008 Mitsubishi Lancer Short Shifter
Please contact us at sales@twmperformance.com for any questions you may have, or if you prefer to place your order by phone please call us toll free at 1-877-655-0540.
Thank you,
Kevin
TWM Performance
Offline
Old Apr 24, 2008, 01:31 PM   #2
EvoM Moderator
Personal Sales Rating: (2)
krnkimchi702's Avatar
Drives: 2008 Mitsubishi Lancer GTS
is this all they make for our cars or are they developing more stuff for our cars??
__________________
Post # 222,222 on APW
XBL tag: PANDAmonium702
Quote:
Originally Posted by andyktlee View Post
Herro? My name Byung with Areejona. I call to ask *CLICK*
Herro? Herro?
Offline
Old Apr 24, 2008, 01:48 PM   #3
Silver Sponsor
Drives: 84 Rabbit
All of our Shift Knobs fit the new 2008 Lancer short shifter as well as the stock shifter.
Check out our new mirror finish available on every shift knob model!
Frank
TWM Performance
Offline
Old Apr 24, 2008, 02:03 PM   #4
MasterAK's Avatar
Drives: 08 Lancer ES MT
Is there a significant increase in shifting effort, or nothing you can't get used to quickly?
Offline
Old Apr 24, 2008, 02:23 PM   #5
Silver Sponsor
Drives: 84 Rabbit
Quote:
Hi MasterAK,
Shifting effort is increased slightly, but it is certainly nothing that you can't get used to quickly. I found the short shifter incredibly smooth and direct during testing, especially with the base bushings. Compared to my STi the shifting effort is significantly less with the Lancer short throw.
Thanks
Kevin
TWM
Offline
Old Apr 24, 2008, 05:34 PM   #6
mines hotter's Avatar
Drives: 2008 lancer gts
are you guys gona come out with a shift boot as well
Offline
Old Apr 25, 2008, 11:27 AM   #7
nunyas's Avatar
Drives: '08 Graphite Gray Lancer GTS
do you have to grease those bushings? Also, I'm curious, why aluminum and not bronze?
__________________
Mods:
Injen CAI - TWM Short Shifter - Tein S-Techs - Tints: (F)35% (R)15% - Clear Bra - VG Sharkfin Antenna - ARS HL2 Front Lip - ARS HL Diffuser
Want List:
Camber Adjustment Bolts - Adjustable Rear Sway Bar - HID Projectors - Cat-Back Exhaust - Wheels & Tires - Analog Oil Press and Coolant temp guages
Offline
Old Apr 25, 2008, 11:41 AM   #8
Silver Sponsor
Drives: 84 Rabbit
Quote:
We could make a shift boot for the Lancer if demand is high. Eventually we would like to have shift boots available for all of our short shifters, but currently there is no ETA for the 2008 Lancer boot.
Thanks,
Kevin
TWM
Offline
Old Apr 25, 2008, 12:00 PM   #9
Silver Sponsor
Drives: 84 Rabbit
Quote:
Hi nunyas,
The aluminum shifter base bushings do not require grease since they are completely stationary beneath the shifter assembly. We chose aluminum for the base bushings since there are no moving parts within them or on their perimeter. They act simply as a replacement for the stock rubber bushings to provide a more solid contact point between the shift assembly and the floor of the car, and as a result improve shift feel.
In the case of shifter cable bushings we would have chosen a material like bronzoil like the rest of our cable bushings since there is rotation within the inner bushing hole and on the exterior perimeter. Base bushings do not experience the same loads so aluminum is ideal.
I hope this helps, thank you for your interest in our products.
Kevin
TWM Performance
Offline
Old Apr 25, 2008, 02:30 PM   #10
nunyas's Avatar
excellent and now that I know what the aluminum bushings are for it makes total sense to me. Thanks for the quick reply!
__________________
Mods:
Want List:
Offline
Old Apr 25, 2008, 03:23 PM   #11
FinestSoldier's Avatar
Drives: 2008 Lancer gts Electric Blue
i have a short shifter installed already. Can i still install the bushings?
Offline
Old Apr 25, 2008, 08:25 PM   #12
Silver Sponsor
Drives: 84 Rabbit
Quote:
Absolutely, even the stock shifter benefits from the base bushings. If you already have a short shifter installed, you can still install the base bushings no problem. They can be ordered from the following link, just scroll down to the shifter base bushings section and choose your car from the drop down menu.
Thanks guys, have a great weekend.
Kevin
TWM
Offline
Old Apr 25, 2008, 09:07 PM   #13
Personal Sales Rating: (4)
mmartahus's Avatar
Drives: Traded 09 GTS for a RR 08 GSR w/ SSS & Aero
How does this compare to the WORKS short shifter model?
__________________
RR 08 Evo X GSR w/SSS, Aero, Interior Sport, K&N Drop In, Buschur Crossflow CBE, Goodyear Eagle GTs, Escort 8500, Perrin Shorty
Sold: GG 09 GTS w/ Sun, Sound, Navi
Offline
Old Apr 25, 2008, 11:11 PM   #14
EvoM Moderator
Personal Sales Rating: (88)
Blacksheepdj's Avatar
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
Quote:
Different logo...
All kidding aside, most short shifters do about the same thing. This TWM kit has the advantage of offering the bushings, though.
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Old Apr 26, 2008, 08:11 AM   #15
just placed my order for the bushings. Hope they do anything
Offline
Tags
2008, gts, lancer, shifter, short, twm, works
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
