lancer es speed sensor issue
by any change you can send me the same diagrama for my 04 lancer ralliart im having the same problem but i dont know witch on is the output and input thanks
[/color]
[/color]
well, for one thing, the input shaft speed sensor and the output shaft speed sensor look different. When you actually look at the two, you'll be able to tell. The input shaft sensor (the one you ordered) has the electrical connector pointing up, whereas the output shaft sensor has the connector pointing off to the side. These pictures should help. The one boxed in red the second picture is mr331743.
what do you mean "switched it", like switched it for a new one? I don't have that option right now...stuck at work. Waiting on the ecu to reset. It was idling fine until I reset the 0715 code, now it won't stay idling. When I try to give it gas, it just dies.
Why would the 0715 code reset effect the iac? Or is it unrelated and just happened to coincide at the same time?
turns out I was just experiencing a stupid coincidence. I was low on gas and parked on an incline, and apparently the pump starving for gas happened at the same time I cleared the code. haha. Way to throw me off the scent! I had pushed it to get it out of the way so I could get it towed if I needed to, and just for kicks tried to start it again and it started right up. Threw the code again today and it runs like junk, so I'll be getting the sensors. Called the dealership and there's nothing specific with the code to tell which sensor needs to be replaced, so I guess i'm getting both just to be safe. $120 a pop, they give a 10% discount for being on evom...but the o/p above had a link for sensors that were $77...different part number for the OZ.
WTB[West]: ABS Wheel speed sensor
aznoy
Dec 27, 2014 11:24 PM
opjohnsmith
Feb 4, 2014 04:56 PM
relliart2004
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jun 24, 2013 08:55 AM
