Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Tranny/Drivetrain Tech
Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 29, 2002, 08:22 PM   #1
Personal Sales Rating: (0)
Lancer - Weak Tranny?
I don't know what you guys think, but I think that one of the bigger flaws of my car is the Transmission. The red line is at 6000 and if I put my car anywhere from 5800 - 6300 I can smell and hear it pushing too hard. I think this is pretty bad considering my friends SI redlines at 8000 and he can push it to about 8700 with no problems at all. I am pleased with the Lancer's low powerband and I think once I get a light flywheel my accelleration will be much faster since the powerband is so low anyways.
Does anyone agree with me and also does anyone have a lighter flywheel and feel they don't need to go into high (lancer-wise) rpm's to get good acceleration?
__________________
Yellow '03 OZ Rally
Offline
Old Nov 29, 2002, 08:26 PM   #2
Personal Sales Rating: (1)
Smoktout's Avatar
Drives: 1996 Mazda Miata
RPW makes a lightened flywheel i think
http://www.rpw.com.au/
__________________
Sex should be like a riced out civic: slow, obscene, and loud enough for the nieghbors to hear
Offline
Old Nov 29, 2002, 09:19 PM   #3
StreetLancer's Avatar
Drives: 04 Civic Si, 02 Mitsubishi Lancer ES [Gone but not forgotten], 03 Mitsubishi Outlander LS AWD
First off, let me say that you are going to have more problems with your engine from running at redline or beyond than you ever will with your transmission (unless you're dumping it at redline). Secondly, that smell you have is more than likely your clutch, depending on the speed and technique with which you are engaging/disengaging your clutch.
Mitsubishi is famous for two things. One, is quality turbos. So much so that many other cars use Mitsubishi turbos from even rival manufacturers, and aftermarket companies like Greddy use Mitsu turbos. The other is Transmissions. Mitsu trannys (at least the 5 spds) are generally considered bulletproof. If there is one place that you are LEAST likely to have a problem with the Lancer, it's that transmission.
__________________
I was StreetLancer. Then I was gearbox. Now I'm StreetLancer again. Now we're up to speed.
Offline
Old Nov 29, 2002, 09:29 PM   #4
Personal Sales Rating: (4)
yellow_lancer's Avatar
Drives: Yellow slO.Z. Lancer 5Spd
Send a message via AIM to yellow_lancer
dsm auto tranny is the worst... sooby's manual is horrible.... well im happy i got some stuff from rrm and it wont matter if the lancer's tranny is weak
__________________
LANCER slO.Z. RALLY
-Nick
Offline
Old Nov 29, 2002, 09:29 PM   #5
Personal Sales Rating: (7)
ryancb's Avatar
Drives: Was Once A Lancer O-Z Rally
Send a message via AIM to ryancb
i really need a new clutch cuse i have beatin mine up bad .....how much is a dealer one anyone know? not sure if im rdy 2 go rrm yet
Offline
Old Nov 29, 2002, 10:12 PM   #6
DaTenshi's Avatar
Drives: Yellow OZ
Send a message via ICQ to DaTenshi Send a message via AIM to DaTenshi
you dont need a new clutch yet it still good it can take more of a beating that what you think~
__________________
Team RedSuns~
Offline
Old Nov 29, 2002, 11:43 PM   #7
ryancb's Avatar
hum just feels like its sliping at high rpms no comment
about why it feels like that but ya it just catches really late and grabes at the last second (not as smooth as used 2 be)
Offline
Old Nov 30, 2002, 12:01 AM   #8
bahamut's Avatar
Drives: 95 white S14 SE
Re: Lancer - Weak Tranny?
First of all, people should really stop comparing tech stuff to H&A products. Some auto companies have their version of variable timing, but they don't have super high revs. Those companies rather have TQ to power their cars with their variable valves system. Unlike H&A, they sacrifice a lot of TQ in order to be fuel misers to achieve super revs.
If you apply your logic of SI's super revs to a 911's TC (yes, the Germans do have their version) at lower revs, the SI has a better tech than a 911. If so, come off the brainwashing. I refuse to believe H&A can make better engines than the Germans. They didn't win all those 12 and 24 hrs endurances for nothing throughout history.
Next, there is such thing as laws of physic, unless somehow having the ability to use space alien's alloy material. Longer conrods equal TQ at the sacrifice of higher rpms. The only exception to this rule is the prelude's 2.2L . . . gotta find specs.
I'm willing to bet if you make a 1.3L rev like crazy if engineered right. Do you think it will have a lot of HP/TQ?
Afterwards, you run into the problem on the ecu setting from the factory. It is set very conservative. Of course, if you have the smarts or enough resources, you can possibly hack into the ecu like Jim Wolf has done for Nissan products.
Lastly, lightened flywheel does not grant you more rpm . . . also, stop thinking reality is based off grand turismo. Yes, you rev faster, but it only changes the curvature of your powerband from broad to a bit more peaky one.
There is no way a lightened flywheel can defy the laws of physic and override fuel cut-off from the factory (it's there to prevent you from spinning a rod . . . yes, your pistons can fly right out of the cyl head. Ask those big block domestics blowing up their engines by spinning a rod or breaking head bolts).
If you don't believe me on the laws of physics, ask ROCK. If you can get forged rods and hacked the ecu, what's the limitation of rpm? It won't touch 8K rpm, unless you using exotic material and super software like in F1 or CART.
I just don't get the fascination of super rpm. IMO, 6700-7000 rpm is the max rpm that I ever want to hit or see. It's call effective powerband. Anymore than that, it takes too much time and effort for an engine to spin so fast . . . wasted energy.
Offline
Old Nov 30, 2002, 12:04 AM   #9
EvoM Administrator
Personal Sales Rating: (8)
HobieKopek's Avatar
Drives: A little red Neon. I also have a Lancer that presumably still rolls...but doesn't drive.
Send a message via AIM to HobieKopek
The redline has nothing to do with the clutch. It has to do with the length of our connecting rods. With shorter con rods and therefore a higher rev limit you wouldn't have as much torque available as early in the revs as you do at present. The con rods are both a blessing (as far as providing torque and a very nice stock powerband compared to other 4's) and a curse (high boost turbo applications). I think it's pretty safe to say that since most of us won't be driving high boost Lancers the pros outweigh the cons.
Don't forget the reason you redline at 6,000rpms is the same reason you should be able to take most comparable 2.0l 4 banger econoboxes. Your friend's Si has a peaky powerband like all honda 4's. High revs, low torque. Low hp and tq at low revs. As a bit of an exagerrated example think of an exponential curve for a Honda's powerband vs a far more linear one for ours.
EDIT: Curses! Beaten by someone who knows far more than me. How embarassing.
__________________
Quote:
Originally Posted by Foggy View Post
I believe the bears are our future
Feed them well, and let them lead the way...
Quote:
Originally Posted by Raphael
Hi. As you can see I'm a bear. I contain no artificial flavors and no artificial colors. Now you may be thinking, "Oh, he's such a cute little bear," but let me tell you I am hard. Really hard. Deep down, I am still a bear. An animal born to raise hell. If I saw a dinosaur right now I'd rip his head off.
Sign up to win prizes by running web searches with Blingo. Powered by Yahoo!
Offline
Old Nov 30, 2002, 12:04 AM   #10
bahamut's Avatar
Nor am I going to debate about the S2000 using motorcycle tech stuff.
__________________
I'll give up my rights if government can tell me, "I'm safer."
They can raid my house since I got nothing to hide.
COMMIES! These people would be better off living in the USSR. The USSR have practically guaranteed no terrorism, because the government focused a large amount of time and effort watching its own citizens.
Edited Quote by me from rivaldufus on SFTT
Offline
Old Nov 30, 2002, 12:10 AM   #11
DaTenshi's Avatar
Drives: Yellow OZ
Quote:
yea it revs like a motorcycle
Offline
Old Nov 30, 2002, 02:24 AM   #12
silverr6's Avatar
Drives: 2001 yamaha r6,2002 oz rally
Send a message via Yahoo to silverr6
One could engineer a motor in a car to rev like a motorcycle, 15,500 rpm redline etc, but it would not be cost effective or much fun to drive. Torque is crap in the upper rev ranges of those motors we play with, power bands are peaky as hell. On the cost issue, 75% of the cost of a new motorcycle is the motor, so it can be way over engineered.
Offline
Old Nov 30, 2002, 06:36 AM   #13
I still say that the mitsu 5 spd is one of the most bullet proof transmissions you can get. If something's weak in that car, that's not it.
I completely agree with bahamut (yet again) that high revs doesn't necessarily mean more usable/effective horsepower. I think that alot of hype is given to the VTEC system (read my quote at the bottom) since it can produce a pretty high HP per liter ratio. However, what alot of people discount is the duration of that horsepower, and where it is in the power band. I mean, look at a common, performance based VTEC vehicle's dyno sheet, and you will see a pretty large spike close to redline, which gives them a high claimed horsepower, but, not for a very long time, and usually at the sacrifice of torque. Does this mean they are faster? Usually if they are like the RSX Type-S, but, for a vehicle like the current Si, it's not entirely impossible to believe that a vehicle like the Lancer with some modifications could take it out. That's saying that a car delivering less horsepower (but more torque), and a lower RPM could possibly win. And for every day driving (unless you're like me), you're probably not going to put the car that close to redline all the time, so, you're not even tapping that HP for daily driving.
__________________
Offline
Old Nov 30, 2002, 08:51 AM   #14
bahamut's Avatar
Quote:
DSM's tranny is weak because of the complex and heavy nature of AWD. Once they are hitting beyond 350 HP, the tendency to break down is greatly increased.
The same with the wrx's, except doesn't have to deal with so much weight like DSMs.
The 3k GT VR4 is even worse. It weights between 3400 - 3600 lbs (more weight than a ZR-1) with their AWD system and the non-reliable getrag 6 spd. Amongst Vette drivers, they called the tranny as "Get Trashed".
As for the same tranny being used with the modern 1.8L, 2.0L, and the 3g 2.4L, I'm sure the tranny will hold up to 250 HP with ease. Of course, the weak point will be the clutch after going beyond 160 HP. It will slip more apparently after reaching more than 200 flywheel HP.
BTW: As you start to reach for insane HP/TQ figures, driving skills will become more apparent. Misshifts will be the #1 killer in tearing teeth and synchros.
Offline
Old Nov 30, 2002, 10:21 AM   #15
Plat Vendor
Personal Sales Rating: (67)
ROCK's Avatar
Drives: faster than you know!
Lots of good info being shared here. I a nut shell though, Lancer 5 speed seems beefy enough to us. The flaw ,if any, is lack of LSD. As for revs, I don't want to rev a Lancer motor more than 6K either. Internals appear to not be strong enough to rev much more. Rod and rod bolts being suspect for higher revs. Flywheel does not look like there is good place to remove material. We wanted to do that right away. Maybe a little bit can be removed but not much.
ROAD/RACE
http://www.roadracemotorsports.com/
__________________
ROAD///RACE MOTORSPORTS-http://www.roadracemotorsports.com
CARBONTRIXhttp://www.carbontrix.com
Quote:
Originally Posted by LegendsoWicked View Post
Take two....
Mistakes Ive seen and done in the past kept me more cautious and aware this time around. RRM does lancers with attention to detail and so I stuck with them this time.
[/IMG]
NOT A WEBSITE, BUT WE DO HAVE A COUPLE OF THEM
Offline
Tags
2002, dumping, fuel, lancer, ls, mitsubishi
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
