Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 26, 2004, 10:27 PM   #1
Personal Sales Rating: (0)
Higgity Hank's Avatar
Drives: '02 OZ
Send a message via AIM to Higgity Hank
Bleeding the brakes is the exact same as bleeding the brakes on any other car. You own an OZ, so you don't have any ABS crap to worry about. Basically, it's a 2 man job... (could go as many as 4, or as few as 1... but that's a different post)
Start at the wheel furthest from the master cyclinder, (passenger rear) take off the wheel, and behind the brake assembly, you'll see a little screw (should be roundabout 8mm in size) It'll have a nipple on it, and a hole in the end. Usually covered with a little rubber cap. You'll want to be careful in turning the screw, because if you break it... (wait for it...) You're screwed. It's not an uber strong bolt... so be careful. A little PB Blaster goes a LONG way in this. Anyhoo, once you're sure it's free, and turns easily, you'll notice that it's leaking a bit of brake fluid from all your turning. Which is what its supposed to do... so you're on the right track. Take a little peice of hose, and put it on the end of the nipple, and run it into a cup/jar/whatever... just don't let the brake fluid come in contact with anything... it's nasty ****. The second person should be sitting in the car, ready for your signal. On your signal have them press the brake all the way to the floor, while you open the screw, and while they're pressing have them let you know how far it's going down... like 3...2...1... close... or similar. You'll want to close the bleeder screw before they bottom out. Then do it again... be sure to keep the Master cyclinder topped off with fluid, and bleed that brake till the fluid is new fluid.
Then move to the brake second furthest from the MC. (drivers rear)
Next would be Passenger front
then Driver front.
be sure to close the bleeder screw before they bottom out the brake pedal, or you risk air in the lines. To test, drive the car... SLOWLY, and press on the brakes. It should be a pretty solid pedal. Pumping the brake shouldn't affect stopping more than giving it a little pusling feel. If the first step is kinda soft, and the second one stops the car more quickly... bleed them again, you've got air in the lines.
It's not rocket science, but it's not something you really want to screw up, since it's a safety issue.
Questions: hit me up with a PM.
__________________
-Hank.
Offline
Old Jan 26, 2004, 11:24 PM   #2
Moderator
Bomb Squad Unit #02
Personal Sales Rating: (14)
urbanknight's Avatar
Drives: a bicycle
Thanks so much Hank! Any idea how much fluid is required for the Lancer? Even so, thanks for the instructions. I am new to doing many of these things to any car, so it's all rocket science to me
__________________
- Brian
Offline
Old Jan 27, 2004, 08:28 PM   #3
Drives: '02 OZ
Buy 2 quarts... if you only use one, return the other.
It doesn't take a lot, but you're gonna scew up (it's inevitable)
__________________
-Hank.
Offline
Old Feb 4, 2004, 08:20 AM   #4
UglyAngelX's Avatar
Drives: 03 OZ/GSXR-750
Send a message via AIM to UglyAngelX
Another way of doing this and eliminating the 2nd person, would be doing it with the use of a MityVac. Same steps, but use the vac to suck out the air and bring the fluid into the lines....all directions are included with the system and it is about 40-60 depending on where you buy it and which version you get. It is a useful tool and eliminates a lot if time and guessing. MityVac can also be used for testing vaccum lines and other stuff. Tool well worth the money for it's many uses.
__________________
It all makes sense at 170 mph.
Offline
Old Feb 6, 2004, 02:24 PM   #5
EvoM Administrator
Personal Sales Rating: (8)
HobieKopek's Avatar
Drives: A little red Neon. I also have a Lancer that presumably still rolls...but doesn't drive.
Send a message via AIM to HobieKopek
Please read the announcement in the how to/install forum.
__________________
Quote:
Originally Posted by Foggy View Post
I believe the bears are our future
Feed them well, and let them lead the way...
Quote:
Originally Posted by Raphael
Hi. As you can see I'm a bear. I contain no artificial flavors and no artificial colors. Now you may be thinking, "Oh, he's such a cute little bear," but let me tell you I am hard. Really hard. Deep down, I am still a bear. An animal born to raise hell. If I saw a dinosaur right now I'd rip his head off.
Sign up to win prizes by running web searches with Blingo. Powered by Yahoo!
Offline
Old Apr 22, 2005, 09:18 AM   #6
EvoM Moderator
Personal Sales Rating: (88)
Blacksheepdj's Avatar
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
Do you bleed the clutch as well? (yes, I'm cross posting. Sorry)
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Old Apr 28, 2005, 10:27 AM   #7
Eddyo's Avatar
Drives: 2003 Mitsubishi Lancer LS
What if you have a lancer ls with the abs? I got some steel braided brake lines and got some of that RBF 600. I want to flush the old fluid and run the new stuff after installing the brake lines.
Offline
Old Apr 28, 2005, 11:24 AM   #8
Personal Sales Rating: (4)
Danno's Avatar
Drives: F150
Quote:
The advice is good but I can see it causeing you a problem in the future.
My OZ has ABS.
__________________
Quote:
Originally Posted by Import Junky View Post
Don't bother asking for help in the OT. Most of these guys won't help you and decide to speak in their own gay internet language. If a word doesn't look right or doesn't make sense just look at the poster, I'm sure they spend most of their time here. Sad and Lame but whatever floats their boats.
Dating Tips
Shaving Tips
Don't Swallow Gum
Candy Nightmare
Know Your Women
Drunkin Pain
Girlfriends For Dummies
Offline
Old Apr 20, 2006, 02:02 PM   #9
Personal Sales Rating: (7)
blaze_125's Avatar
Drives: Yellow OZ
Quote:
My OZ has ABS.
Out of the dead thread, cause I'll be changing my brake fluid this weekend. So my OZ also has ABS. Is there a different procedure for cars with ABS brakes?
And what's up with this?
As you're bleeding, you gotta keep adding new fluid in the tank? Won't both mix together?
Once you've done it on the first bleed screw, the system should be filled with new fluid, and there should only be old fluid in the other 3 lines right... So basically, only the first bleed screw is going to take longer as you have to empty the whole old fluid?
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Old Apr 21, 2006, 10:45 AM   #10
EvoM Moderator
You gotta keep adding, yeah. Otherwise, you get air in the lines from that end.
Easiest way - get colored fluid. I got ATE's Super Blue, so I just knew to stop bleeding when the fluid turned blue. Next change, I'll get a normal yellow or clear.
Yes, the first screw will take the longest.
__________________
Modern Warfare 2
Offline
Old Apr 24, 2006, 07:28 AM   #11
blaze_125's Avatar
Drives: Yellow OZ
Well... I did it and jeez did it ever need to be changed(3 year old fluid). My brakes felt really inconsistent before the bleed. When I bled the lines the amount of air that was in there was just incredible.
Now it brakes like a champ. To anyone who thinks their brakes are s*cking really bad lately, try bleeding them.
__________________
Offline
Old Oct 13, 2009, 07:33 PM   #12
Personal Sales Rating: (1)
rsardelli's Avatar
Drives: 06 Mitusbishi Lancer Evo GSR
im having my buddy who is a harley davidson master tech help me with this. The great thing about that is all HD MST's need to go through a course to familiarize them with almost all OEM Brembo systems since Brembo is the new OEM brake system on all 2010 HD motorcycles, and he went to school to work on cars as well. If your only option is a H-D tech, he prolly know what hes doing.
__________________
Rich
'06 GSR Electric Blue
XBOXLIVE BELTFEDASSASIN
A Marine Sniper was asked what he felt when he shot an insurgent.
The Marine just shrugged and replied "Recoil"
Offline
Old Oct 14, 2009, 06:55 AM   #13
blaze_125's Avatar
Drives: Yellow OZ
Nice 3 year bump!
__________________
Offline
Tags
brakes, f150, ford, pusling
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
