Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 23, 2009, 11:14 PM   #1
Personal Sales Rating: (0)
djslik408's Avatar
Drives: 2005 Evo & 2008 Lancer GTS
Send a message via AIM to djslik408
rear camber kits
Is there one available for an 08 GTS? I had alignment and my rear is off by 2.1. Where can I get the kits for an 08 if there is one available? Thanks.
Offline
Old Nov 3, 2009, 12:03 AM   #2
Drives: Tarmac Black 08 Lancer GTS
someone recommended me to get cambers, but im actually a noob to this, what exactly does this camber do? i wanted to run bigger rims and tires on my gts, and they recommended me to run some cambers. what is that suppose to mean?
__________________
Mods
-6000k BiXenon E55 Projectors w/Angel eyes-Yellow Fogs-LED(City lights, Interior Lights, License Lights)-MMCS Navigation-Debadged-Tints-Smoked(Tails, side markers, rear reflector, 3rd brake lights)-Injen CAI-HKS Hi Power Exhaust-VG-Shorty Antenna-Blacked Out Front-Mitsu Red Emblems-Red Calipers
To Be Installed
-OEM Ralliart Front Bumper-OEM Evo X GSR Enkei Rims-EvoX MR Spoiler-Side Plate Mount
Want
EvoX Hood-LED Side Mirrors-OEM MR Recaros-Sound System-New Brake Pads/Rotors-Front/Rear Lip
Offline
Old Nov 4, 2009, 12:41 AM   #3
seanymack's Avatar
Drives: 2009 Lancer DE @_@
camber kits are used to keep your wheels properly aligned. usually you dont need one unless you are thinking about lowering your car. lowering affects the angle of which the tires meet the road.
maybe someone else could explain why bigger rims and tires would need a camber?
djslik408 try looking around for an Ingalls Camber Kit.
__________________
For Sale: K&N Drop in Filter $30
Offline
Old Nov 4, 2009, 06:48 PM   #4
so if i put evo x rims i must get cambers huh? what would be a good spot in toronto to buy them from?
__________________
Mods
To Be Installed
Want
Offline
Old Nov 4, 2009, 08:45 PM   #5
djslik408's Avatar
every time you lower your car, the all geometry of the weight changes. Thats why you need the kit to get it aligned. Depending on how low you drop it, you may not need it if it isnt too dropped. In some cases it may just be off by a few degrees while in some, it may be way off.
Offline
Old Nov 4, 2009, 10:07 PM   #6
alright thanks alot, how much do they run for anyways?
__________________
Mods
To Be Installed
Want
Offline
Old Nov 8, 2009, 04:32 PM   #7
djslik408's Avatar
Front Cambers go for $89 I believe if you order them from RoadRoad motorsports. I havent seen anything for the rear though.
Offline
Old Nov 9, 2009, 06:29 AM   #8
Personal Sales Rating: (1)
Drives: 2008 Grey Lancer GTS (5spd)
Send a message via AIM to kalpakiotis
Quote:
Bigger wheels will change the distance and angles for your suspension. If you draw out a right triangle you can see how changing one side will increase the angles. Camber kit will allow you to readjust those angles, but I wouldn't think wheels alone would be enough to warrant a camber kit.
__________________
HID Lo/Hi/Fog
RRM SRI V2
RRM TCM
Works Short Shifter
Megan Coilovers...if interested in the stock GTS suspension, pm me.
Offline
Old Nov 9, 2009, 07:59 AM   #9
EvoM Moderator
Personal Sales Rating: (2)
krnkimchi702's Avatar
Drives: 2008 Mitsubishi Lancer GTS
Quote:
ingalls has them for like 30 bucks for a pair
__________________
Post # 222,222 on APW
XBL tag: PANDAmonium702
Quote:
Originally Posted by andyktlee View Post
Herro? My name Byung with Areejona. I call to ask *CLICK*
Herro? Herro?
Offline
Old Nov 9, 2009, 08:41 PM   #10
csL
csL's Avatar
Drives: 2008 Lancer GTS
Does the eibach prokit need them?
Offline
Old Nov 9, 2009, 10:07 PM   #11
djslik408's Avatar
Once you get your alignment and you look at the printout you will see. My rear was off by 2.1 on one side and the other was like 1.6. It should show it in red color. If its green you are fine.
Offline
Old Nov 10, 2009, 05:20 AM   #12
csL
csL's Avatar
Ok cool, thank you.
Offline
Tags
06, 08, 09, bolts, camber, evo, evolution, ingalls, kit, lancer, raer, rear
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
