Oct 13, 2009, 12:37 PM
Personal Sales Rating: ( 7)
Drives: Yellow OZ
how do I check lower ball joint
The steering wheel shakes when I go past 100km/h
Sometimes it's pretty violent, sometime it's not too bad, sometime it doesn't shake at all.
Braking or stearing make no difference.
I know there is a very slight play in the wheel bearing, but I'm leaning towards a faulty ball joint... Does anyone have a procedure to check the lower balljoint?
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Nov 2, 2009, 04:26 PM
Personal Sales Rating: ( 4)
Drives: '82 VW Caddy -- '80 VW Scirocco 8v -- '76.5 Super Scirocco
Jack that corner up off the ground, then push and pull on the wheel, get a finger or two on the ball joint while you're doing this, if you can feel movement, it's toast. But, it is unlikely that a bad ball-joint is causing steering wheel vibration. My current DD has bad lower ball joints on both sides and the most I get is an occasional 'loose' feeling in corners.
Offline
Nov 3, 2009, 12:37 PM
Personal Sales Rating: ( 13)
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Normally when the wheels starts shaking at highway speeds it mean your wheels are not balanced. You could have had a weight fall off or something, I would bet money this is your problem, twardnw is correct your ball joint wont make it shake, if it was bad most likely you would hear a clunking sound when going over bumps.
__________________
16G Turbo build: Build completed tuning time
Offline
Nov 3, 2009, 12:44 PM
Personal Sales Rating: ( 12)
Drives: 03 evo ,02 ws6 trans am
sounds like unbalanced tires or possibly warped rotor or brake related problem.. does it happen when u apply brakes???
__________________
03 evo 8
turbo trix 50 trim turbo kit
1mm oversized valves
hks 272/272
aem ems
aem wideband
b&m short throw
soon to be kelford 280's with the new pte 5857..
Offline
Nov 4, 2009, 08:50 AM
Drives: Yellow OZ
Quote:
Nope, only at high speed.
I haven't had a chance to really look into it yet, but I have to get 2 new tires up front anyway. So once I got the new rubber on I'll see if it still shakes or not
__________________
Offline
Tags
bad, ball, caddy, do, front, joint, joints, lancer, lower, shaking, sounds, wheel  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
