Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 11, 2009, 03:22 AM   #1
Personal Sales Rating: (0)
Miha's Avatar
Drives: Lancer Instyle 2.0 DID
Lancer 08 - offset question
I wonder if anyone knows will be rubbing if I mount following rim:
- 18 * 7.5 offset 35
I have time until Monday, when the contract may be changed for the ET42.
tx
Offline
Old Sep 11, 2009, 05:30 AM   #2
EngRWW33's Avatar
Drives: 09 Lancer GTS M/T
that's a good question. I know that with a wider wheel you would be rubbing a bit in the rear (sounds dirty... lol), but with a 7.5" wide wheel it might be different at stock height. Either way, you would be better off with rolling the rears or going with a higher offset then +35.
Offline
Old Sep 11, 2009, 06:37 AM   #3
Miha's Avatar
tx
but with et35 will look good
Offline
Old Sep 12, 2009, 11:23 AM   #4
Personal Sales Rating: (1)
cRc`22's Avatar
Drives: WW 08 GTS
Send a message via AIM to cRc`22
at stock height running 18x8+35 235/40 i only rubbed in the rear passenger side as long as u run a smaller tire since ur only gonna have a 7.5 inch wide rim u should be fine even if lowered..
__________________
--Injen Cold Air Intake
--WORKs Drop-In
--Injen SES Exhaust
--WORKS TUNED
--WORKs Rear AntiSway Bar
--HAWK HPS Front Pads
--WORKs 4 Corner SS Brake Lines
--MeganRacing Coilovers
--Enkei RPF1 18x8+35
ForSale :: Stock 08-09 GTS RearSwayBar. upgrade for 08-09 DE/ES models http://forums.evolutionm.net/sale-wh...-bar-20mm.html
Offline
Old Sep 14, 2009, 01:30 AM   #5
Miha's Avatar
It's lowered -3,5 with H&R
Offline
Old Sep 14, 2009, 08:44 AM   #6
JHizzle's Avatar
Drives: Evo X GSR,08 GTS (for sale), and a K20 again.
Quote:
yeah same here..i get the occasional rub on the rear passenger..and it rubs if i have people in the back seat harder..gonna get it fixed soon..so with 7.5 rims you should be fine
Offline
Old Sep 14, 2009, 09:40 AM   #7
Miha's Avatar
I take now ET42. I ordered wheels from the UK, so that they then can not return. Would be large costs.
Offline
Old Sep 16, 2009, 03:48 PM   #8
Drives: lancer 08
I have 18x7.5 w/ et:42, I am running 225/45/18 and my car is also lowered by h&r, I have no problem or rubbing. I hope this helps. I think it should be good but can't tell, I can check it if you want to bring your car to the shop I own a car accessories, rims and tires. Im not sure where you from? thanks,
Offline
Old Sep 22, 2009, 03:31 AM   #9
Miha's Avatar
I'm from Slovenia (Europe). I ordered now 18''*7,5 with tires 225/40/18
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
