Sep 2, 2009, 02:27 PM
Personal Sales Rating: ( 0)
Drives: 03 mitsubishi lancer oz rally edition
camber kit ????????
i just installed my lowering springs yesterday n got ma car aligned 2day n they told me tha cause off my lowering springs they couldnt adjust my camber :/ so now i really have 2 buy a kit 4 it so i really need help in where i could buy it thanxs guys
Offline
Sep 2, 2009, 02:30 PM
Personal Sales Rating: ( 1)
Drives: 90'lysholm charged corrado, 02' 337 gti 1.8T ,02 gti 1.8T,TB EVO IX
not enough question marks in your title so i cant help you out.
Offline
Sep 2, 2009, 02:34 PM
Personal Sales Rating: ( 18)
Drives: 2006 Audi A4 Quattro 2007 Mazda CX-9
We carry the Ingalls 14mm cam bolts for the front end. One bolt will give +/- 2 deg of camber, the other +/- 1 deg of camber. Both options are in stock.
__________________
Neal, Sales Representative
1-877-522-8473 ext 624
www.tirerack.com
Offline
Sep 2, 2009, 02:48 PM
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
Not to bump out Neal@tirerack since he is a great guy, but I got my set(2) off of ebay for about $20...
Offline
Sep 2, 2009, 03:07 PM
Drives: 2005 Lancer OZ Rally
Isn't that almost the same price as TireRack?
One thing I've discovered is that there are shops who don't know how to adjust camber on our cars. Why, I'm not sure, but I've run into that.. They can't seem to see the camber adjustment on the front end. Story I got was that ALL fwd cars have solid front ends - which obviously isn't true!
Offline
Sep 2, 2009, 03:14 PM
It's pretty close. The Ingalls I purchased could go up to -2 - +2 and was $20 for both, not $20 each(making it $40)
Offline
Sep 2, 2009, 03:31 PM
cause my rear caster both are sitting right now is -2.0
Offline
Sep 2, 2009, 03:58 PM
my cars rear tires are leaning towards tha inside of tha car like in an angle n they told me tha in a couple of months if dont fix it tha i will have to buy new tires cause tha inside will get worn faster
Offline
Sep 2, 2009, 04:17 PM
Well the camber kit is for the front... The rear is pretty adjustable... I had mine set back to 0 and it was almost to the tire...
Offline
Sep 2, 2009, 07:55 PM
Quote:
Oh ok, my bad.
Offline
Sep 2, 2009, 10:54 PM
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
Quote:
go to a different place. They don't know what they're talking about
Offline
Sep 3, 2009, 08:37 AM
Well if I try 2 adjust my rear camber tha max tha it will reach is -1.2 degrees but if I do leave it there tha toe will b all messed up so I told them 2 leave tha camber -2.0 so tha toe is bak at zero so idk wat 2 do n wat 2 buy so tha rear camber goes bak 2 zero n my front is fine
Offline
Tags
05, 08, 2004, a4, adjusting, adjustment, audi, camber, caster, kit, kits, lancer, mitsubishi, oz, rally, rear  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
