Aug 21, 2009, 10:43 PM
Personal Sales Rating: ( 0)
Drives: Lancer GTS 2009
Drag DR-19... This is how its looks on the GTS
Pics helped me out a lot when I was shopping for wheels - so hope this helps anyone who might be looking to put this type of wheel on their GTS... Not for everyone, but I'm quite happy with it.
According to Drag Wheels, the DR-19s are 21lbs (I believe the OEM wheels are 23lbs).
Am running on 225/45/18 Yokohama YK520s - much quieter than stock tires. If you are looking for more performance (and still want to stay with all season tires), a good one to look at is the new Goodyear GTIIs.
Offline
Aug 21, 2009, 10:57 PM
Drives: 08 Lancer ES MT
They look good on a silver lancer.
Also for those who are looking for similar mesh style wheels, the Enkei RPM2 and EKM3 are worth a look too.
__________________
2008 Electric Blue Lancer - 5 spd
☑ Works Rear Sway Bar
☑ HKS Drop-In Filter
☑ 17x8 Rota DPT / Falken FK-452
☑ Rally Armor Basic Mud Flaps
☑ 20% Tint
☑ DDM SlimLine 4500K HID with DRL defeat harness
☑ Fog Light Kit
Offline
Aug 21, 2009, 11:53 PM
Personal Sales Rating: ( 1)
Drives: WW 08 GTS
ekm3's look good
__________________
--Injen Cold Air Intake
--WORKs Drop-In
--Injen SES Exhaust
--WORKS TUNED
--WORKs Rear AntiSway Bar
--HAWK HPS Front Pads
--WORKs 4 Corner SS Brake Lines
--MeganRacing Coilovers
--Enkei RPF1 18x8+35
ForSale :: Stock 08-09 GTS RearSwayBar. upgrade for 08-09 DE/ES models http://forums.evolutionm.net/sale-wh...-bar-20mm.html
Offline
Aug 23, 2009, 12:46 AM
Drives: 2009 Lancer GTS
I've been eying this rim for a long time now, it's looks nice. How much did it cost you including the tires? I like the black one for my Rotor Glow.
Offline
Aug 23, 2009, 08:48 AM
Drives: 09 Lancer GT
^ Humble you should go with something with a red stripe and get it painted to match your car colour. I think that would look sick  . Just a suggestion.
Very nice wheels  .
__________________
09 GG GT Lancer
Apexcone 6000K HID
Evo X CF hood
RRM CF diffuser
18 Tenzo M1 w/ HTZ III
Ingalls Camber Kit
Rays Lugnuts
Eibach Sportline
Ralliart Tails
Sparco Shifter
VG Shark fin
30% Solarguard tint
Pioneer 700bt w/ Siruis
Lamin-X Headlight tint
Offline
Aug 23, 2009, 02:27 PM
Quote:
Very nice wheels  .
Yeah that will work too
Offline
Aug 24, 2009, 09:34 AM
Quote:
Got them at Discounttire.com... Very reasonable $130 for wheels, the Yokohama's run around $150+ and with new TPMS sensors my whole package came to $1301 (including shipping)... Also quite happy with their customer service...
Offline
Aug 30, 2009, 06:53 AM
Quote:
Did you have to take it to the dealer to have the new TPMS codes downloaded to the ECU? If so How much did they charge? J/c.
Offline
Aug 30, 2009, 10:46 AM
Drives: WW 08 GTS
Quote:
u just put the TPMS in from ur stock wheels and then drive off.. the only thing ull have to pay for is for them to swap the TPMS into the new rims should cost $5 per wheel
__________________
--WORKs Drop-In
--Injen SES Exhaust
--WORKS TUNED
Offline
Aug 30, 2009, 11:05 AM
Quote:
Yea, I know that. I thought gcchelsea bought new TPMS sensors. I was curious what the dealer charged to reprogram the ECU. I am curious b/c from what I have read, if you got a new set of wheels with new sensors, you would have to reprogram the ECU. See link below:
http://www.mitsubishi-tpms.com/Mitsubishi-Endeavor.htm
If he bought new sensors I was curious what they cost for Mitsu to reprogram the ECU.
Offline
Aug 31, 2009, 06:58 AM
Yup, had to take it to the dealer... Service manager there is a good guy and charged me 30 min labor ($47) total... Most other dealers will charge 1 hour for it. Call around.
As you probably know, you do need to get to the ECU so it is a "dealer only job." I learned the hard way since I first took it to a National Tire and Battery that charges only $4 per TPMS. Problem is TPMS light doesn't turn on until you drive above 40 mph so it initially looked like it worked. The folks at National Tire and Battery (in Natick, MA) had absolutely no clue... Definitely would avoid them in the future (at least the one in Natick, MA).
Offline
Aug 31, 2009, 06:31 PM
I guess that isn't as bad as i thought it would be. I think it is rediculous what Mitsu is charging for some of these services, but it is what it is. I guess thats one of the services you have to just suck up and pay for if you replace the sensors. Thanks for the info
Offline
Oct 9, 2009, 08:51 AM
Personal Sales Rating: ( 2)
Drives: 2009 Lancer GTS BLK/BLK , 2008 Mitsubishi Lancer Es
on my wheels on my 08 and 09 gts i simply swapped them from my stock set to the new set and they worked no problem there is NO need to have them reset the ONLY time you need to have them reset is if a sensor has failed. simply getting new tires/wheels DOES NOT require you to go to the dealer. Trust me ive done this twice on my 08 and once on my 09.
__________________
2009 Black Lancer GTS S&S, OEM EVO X hood , EVO X Recaro Seats, 2.4L Injen CAI, 18x8 MSR 045 225 40 HP Fierce tires, Carputer w/ 7" touchscreen running Centrafuse 1.47, Blacked out grille , Autopager 2 Way Alarm, Escort Passport 8500 X50 with ZR3 Laser Shifter, 20% Tint
Offline
Oct 10, 2009, 01:12 PM
I bought NEW sensors, hence the reset (had a guy lined up for the old OEM wheel/tire/tpms set).
But yes, if you are just swapping them out no need to do anything...
Offline
Oct 13, 2009, 12:40 AM
Drives: 2008 lancer gts cvt
rpf1's ftw(:
Offline
Tags
09, 18, 19, 2008, car, dr, dr11, dr19, drag, evo, gts, lancer, tire, wheel, wheels  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
