Aug 17, 2009, 09:32 AM
Personal Sales Rating: ( 0)
Rear Drum Brake Conversion Kit for ES?
I want to buy a new Lancer, but for monetary reasons (I'm broke) it is probably going to be an ES. My plan is to run it for a while as stock, but then start modifying it.
I HATE drum brakes, so is there any conversion kit to go from the rear drums to rear discs in the ES?
Offline
Aug 17, 2009, 12:21 PM
Personal Sales Rating: ( 2)
Drives: 2009 Lancer GTS BLK/BLK , 2008 Mitsubishi Lancer Es
the es has rear discs the DE has drums if your strapped for cash look for a used lancer rather than new, they depreciate rather quickly.
__________________
2009 Black Lancer GTS S&S, OEM EVO X hood , EVO X Recaro Seats, 2.4L Injen CAI, 18x8 MSR 045 225 40 HP Fierce tires, Carputer w/ 7" touchscreen running Centrafuse 1.47, Blacked out grille , Autopager 2 Way Alarm, Escort Passport 8500 X50 with ZR3 Laser Shifter, 20% Tint
Offline
Aug 17, 2009, 01:10 PM
Drives: 08 Lancer ES MT
Quote:
Actually the ES used to have rear discs (mine does) but the second shipment of the ES models had drum brakes. Instead they added a lip spoiler.
To the OP:
I hate drum brakes too but consider that if you convert from the rear drum brakes to disc brakes, it is going to be for looks rather than any performance benefit. Looking for a used low mileage car is always a good option and will save you some cash.
__________________
2008 Electric Blue Lancer - 5 spd
☑ Works Rear Sway Bar
☑ HKS Drop-In Filter
☑ 17x8 Rota DPT / Falken FK-452
☑ Rally Armor Basic Mud Flaps
☑ 20% Tint
☑ DDM SlimLine 4500K HID with DRL defeat harness
☑ Fog Light Kit
Offline
Aug 17, 2009, 01:16 PM
Whoops I meant the DE not the ES...I always get them confused.
I was looking to trade my car in using "cash for clunkers" so it has to be a new one.
Offline
Aug 17, 2009, 01:35 PM
id try to get a deal on an es or gts, right now mitsu has 1500 off then the 4500 cash for clunkers then try to talk the dealer down another 2k, make sure to stress to them that the 3500-4500 from clunkers and the 1500 is NOT out of their pocket, they will try to seem like THEY are giving you a deal when the car is 6k off msrp when THEY arent doing anything. my father in law used this tactic with jeep dealer and it worked quite well.
first thing to say is, Lets Start off at 1250 off msrp, not including mitsubishi rebate or clunkers, if they say no go to another dealership. remember it isnt uncommon for dealerships to go down on price 1k-3k without using factory rebates, dealers are just trying to get by without discounting their stock by using the govt rebate and mitsu rebate as their own incentives.
good luck man.
__________________
Offline
Aug 17, 2009, 01:38 PM
also to "MasterAK" thanks for the clairication.
to the op make sure if u do get a de that it does have AC and if it doesnt have air conditioning make sure you KNOW that a head of time and use it as a bargaining chip.
__________________
Offline
Aug 18, 2009, 11:32 AM
Thanks for the advice lancer0220. I'll make sure to use that tactic.
Offline
Sep 8, 2009, 09:45 AM
Drives: lancer 2008
forget about changing to disc brakes, its useless, unless your planing some serious performance driving, and its going to cost you alot of cash(assuming $$ is the reason your not buying it with disc brakes in the first place), spend that on wheel&tires, that will improve performance and do more for the looks then disc brakes in the oem steels rims of the ES.
But do your best effort and try to get the abs package, its better and youll get discs all around
Good luck!
Offline
Tags
03, 2002, brake, brakes, conversion, convert, disc brake, disks, drum, drum brake, drums, es, escort, lancer, mitsubishi, rear  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
