Quote:
Originally Posted by EngRWW33
They will fit. But those tires suck!! Get some new rubber!!
Concur - Stock Dunlop Wheel width range is 7 - 8 inches
Absolutely Concur - Stock Dunlop Tire sucks. Athough a little noisy due to the all season slits on the tire and 360 treadwear, When you load the tire (laterally) during "spirited driving through corners" the tire will roll over on it's sidewall and you will loose traction. This can be minimized by increasing tire pressure to 45-48PSI, but if you hit a pothole, the tire is toast at that pressure. I won't bore you by talking about slip angle, camber, roll stiffness and their effects on lateral load, I'll just end it by saying replace them if you can.
