Jul 25, 2009, 05:11 PM
Personal Sales Rating: ( 0)
Drives: 2008 lancer gts
tire advice
i was thinking about purchasing some goodyear eagle gt's or nitto invo anyone have any complains about them im also going with a 225 45 18 for a slightly wider tire im lookin to spend about 130 topss
Offline
Jul 25, 2009, 05:14 PM
Personal Sales Rating: ( 3)
2002 Ford Focus
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
The GY Eagle GTs seem to be a good tire from all that I have seen/tested on them.
I'll be picking up a set myself for my new car next week.
Offline
Jul 25, 2009, 05:46 PM
yeaa i heard they were pretty good i heard the nittos were awesome but there only a summer tire and im gona need something thats okay in snow as well
Offline
Jul 27, 2009, 05:41 AM
Personal Sales Rating: ( 1)
Drives: 2008 Grey Lancer GTS (5spd)
I have the invo's on mine right now. Its a really nice setup. Dry weather they hold to almost any corner and after driving on them for a while they are a lot more predictable on when they break free then with the stockers. As for the rain, they are really decent going straight, I don't tempt to many corners at high speed, I have gotten my rear end out on me a couple of times around exits and in town.
__________________
HID Lo/Hi/Fog
RRM SRI V2
RRM TCM
Works Short Shifter
Megan Coilovers...if interested in the stock GTS suspension, pm me.
Offline
Jul 30, 2009, 05:43 PM
Drives: 09 Lancer GTS
Quote:
not possible with a FWD car
__________________
2009 Graphite Grey Lancer GTS Manual, S&S, Navigation, 20% 3M tint, black out front bumper and grill, shorty antenna, TWM short throw shifter
Eat it while it's HOT!
Xbox Gamer Tag: PeeFour
Offline
Jul 30, 2009, 06:16 PM
Drives: 2009 Lancer GTS
Quote:
Yes possible! On a FWD car with a high enough spring rate (higher than the front spring rate) in the rear suspension. Megan coilover spring rates are 8k in the front and 10k in the rear. this will allow a car to oversteer through a turn. Same effect as lower tire pressures in the rear and left foot braking before a turn. Oversteer and understeer are a function of center of gravity. FWD cars understeer because they are infact heavier in the front, however you can correct for that as stated above. Read a racing suspension book! Or a car handling book!
Offline
Jul 30, 2009, 06:18 PM
2002 Ford Focus
Very possible. In fact, I am counting on it with my new car
He is not talking about drifting, billowing smoke off the rear tires...
Offline
Jul 30, 2009, 08:11 PM
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
It is possible, I've experienced it at the worst places
Offline
Aug 1, 2009, 07:40 AM
Quote:
with exception to the Megan coilovers and the stock suspension on the GTS, most of the aftermarket kits (eibach, tien, tanabe) have slightly higher spring rates in the front for safety. it is much safer to understeer with a car than to oversteer. As for tire pressures i run 42F/42R for commute and 49F/45R on the track, but that is autocross and the turns are about 40mph max. you guys be careful running with lower tire pressures in the rear or using the Megan Coilovers. At cornering speeds greater than 40mph, things can go very wrong real quick. For autox you want a small amount of oversteer to turn the car around the corner.
Offline
Aug 1, 2009, 01:13 PM
Drives: the Batmobile
i've oversteered on stock suspension
go into a turn in decent speed keeping throttle @ atleast 1/2 way in, middle of turn lift off throttle
shifts the weights of the car from more balanced around 50/50 when cornering @ while on the gas 1/2 throttle and up to 60/40 right away, causing rear tires to break loose
too much throttle and u'll understeer, too little and ur cornering too slow
i've done it many times
__________________
2009 Tarmac Black Pearl Lancer SE...5sp MT
Offline
Aug 1, 2009, 02:16 PM
there is definately more than one way to do it. Having the CVT, what I do is gas pedal to the floor through the straitaway going into the turn, just before i begin to turn, break hard with my left foot to load the front tires lift the gas pedal to about 1/2 throttle then tap the brakes until the rear breaks loose and put the gas pedal back to the floor at the apex of the turn. most of the time this will work unless the turn is off camber. then you have to use other tricks. I have been getting better and better with my left foot braking and it is shaving pretty good time of my lap times. The left foot braking also prevents the cvt from trying to shift when you don't want it too.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
