Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 8, 2009, 04:30 PM   #1
Personal Sales Rating: (0)
dustyp34's Avatar
Drives: 08 lancer es
tanabe springs
whats up guys I been thinking about getting some springs and I like the tanabe springs. I was wondering if anyone has these springs and what do the think of them.
__________________
Added: Gts Wing
Tint
Xbox Live Tag: BabyBoy34
Offline
Old Jul 8, 2009, 04:57 PM   #2
Personal Sales Rating: (2)
Drives: 2009 Lancer GTS BLK/BLK , 2008 Mitsubishi Lancer Es
Send a message via AIM to lancer0220
i havent seen anyone with tanabe springs but my friend with his 04 350z has tanabes and he recommends them over any spring. he says the drop is just enough not to kill the factory struts. when i ever do drop my car i am going with tanabe.
__________________
2009 Black Lancer GTS S&S, OEM EVO X hood , EVO X Recaro Seats, 2.4L Injen CAI, 18x8 MSR 045 225 40 HP Fierce tires, Carputer w/ 7" touchscreen running Centrafuse 1.47, Blacked out grille , Autopager 2 Way Alarm, Escort Passport 8500 X50 with ZR3 Laser Shifter, 20% Tint
Offline
Old Jul 8, 2009, 05:05 PM   #3
jer301's Avatar
I am not that farmiliar with these springs, but I have had a couple of drivers recommend them. I am working on a suspension design and could tell you what spring rates to go with (provided the suspension geometry is the same as the GTS). I guess it depends on what you want to do (road race, autox, our just spirited street driving). What are you looking for? just lowering the car? or tuning to a higher frequency response?
Offline
Old Jul 8, 2009, 05:16 PM   #4
dustyp34's Avatar
really want the car to handle better without slamming the car to the ground. also I dont want to sacrifice ride quality.
Spring rates=3.7(F) / 3.6(R) Spring Drop=1.1(F) / 0.9(R)
__________________
Added: Gts Wing
Tint
Offline
Old Jul 8, 2009, 06:09 PM   #5
jer301's Avatar
I will pm you the numbers in the morning. I left my flashdrive at work. Stiffer springs (provided you don't go too stiff) are really not going to affect your ride quality. That is your tires and dampers. A stiffer spring will just keep the tire on the ground and give you better traction for higher speed cornering, roll stiffness, etc. Of course the most critical number you need I don't have but will try to measure tonight: spring hieght. Looks like they have a kit for the 07 08 lancer on their site
P# = TNF136
http://www.tanabe-usa.com/search3.asp#
I would just go with the kit if you are not looking for specific freq tuning
Offline
Old Jul 9, 2009, 12:52 PM   #6
jer301's Avatar
Okay man,
Sorry for the delay but I left my car data at work. Based on the numbers you provided, here is where we are:
Stock spring rates for the gts (yours might be lower) are as follows:
Front = ~170 lb/in (~3.1 kg/mm)
Rear = ~200 lb/in (~3.6 kg/mm)
Your new kit from Tanabe would be as follows:
Front = 3.7 kg/mm (~207 lb/in)
Rear = 3.6 kg/mm (~202 lb/in)
Front Drop = 1.1”
Rear Drop = 0.8”
This will lower the car base on the info provided and you will probably notice a difference in cornering ability. The progressive kit (P/N 4.486) from Eibach will give the following:
Front = 103 – 263 lb/in
Rear = 103 – 217 lb/in
Front Drop = 1.2”
Rear Drop = 0.9”
Progressive springs will give you a comfortable ride at low speeds and stiffen up for high speed cornering.
Either one of these kits will be great for your car. The Tanabe could be faster in cornering, but that is b/c the spring rate is contstant through various loading conditions.
If you want to do road race or even autox, I would recommend the following:
Front = ~275 lb/in (4.9 kg/mm)
Rear = ~350 lb/in (6.3 kg/mm)
This will be a rough ride on the road, but the car will corner great. I may actually go higher on my set up but not sure yet. I might not do anything to the suspension except dampers b/c I want to stay in H stock. I don’t think the lancer can compete in Street Prepared or Street Mod classes, it is too heavy, and does not have enough power. The reasons for increasing the rear spring rates so much for racing are as follows:
1) The front suspension is a McPherson strut suspension with a motion ratio of 1.103. The rear suspension is a multilink suspension which provides good caster and camber control through the entire range of motion, but the motion ratio is much lower (0.553 on our vehicles). Thus you will need a much larger spring to increase the wheel rate of the rear tires.
2) Ideally a perfectly balanced (same weight at all 4 tires) car with a low roll center would not oversteer or understeer. Vehicle manufacturers and spring manufacturers (unless they are building racing cars) usually set the spring rates the same for the front and back or they make the front spring a higher rate. This is for safety. It is safer to understeer with a car than to oversteer. To compensate for this, autox’rs and road racers usually either increase the rear spring rates, or decrease rear tire pressure, or a combination of both. For cornering, a little oversteer will get the car around the corner a lot faster than a lot of understeer.
Hope this helps.
Offline
Old Oct 8, 2009, 12:59 AM   #7
2009 Mitsubishi Lancer
Do you have the number for Eibach Sportline Kit?
I'm comparing this to the Tanabe...^^"
__________________
'2009 GTS - Octane Blue CVT
- Advan RS Gold
- Eibach Pro-Kit F1.2" & R0.8"
- Colt-Speed Hood Dampers
- VG Functional Sharkfin Antenna
- 25% Tint
Online
Old Oct 8, 2009, 05:55 AM   #8
jer301's Avatar
No but if you call them and ask they will tell you. Eibach is very good about sharing info. They understand that some people are designing and setting up ther own suspension so they will give you the spring rates of most of their kits. I have only ran into one company who does not share this info
Offline
Old Oct 8, 2009, 05:48 PM   #9
One more question about the Progressive springs... what exactly is that?
For my understanding, the distance between the coils are different.... what is the point of that?
Many Thanks!!
__________________
- Advan RS Gold
- 25% Tint
Online
Old Oct 8, 2009, 05:52 PM   #10
Personal Sales Rating: (77)
AF-Evo8's Avatar
Drives: 2003 TB EVO VIII
i have the GF210 on my evo and love them, perfect drop and not to rough during city driving.
__________________
Check out my F/S Thread
Parts F/S, OEM headstuds, OEM Connecting Rods, Ebay 3" Downpipe, Ebay Cat-back Exhaust, Innovate DB Wideband Gauge, OEM Intake Manifold, OEM Valves/ Valve springs and retainers, Perrin Lightened Crank Pulley ETC. http://forums.evolutionm.net/sale-en...take-look.html
Offline
Old Oct 8, 2009, 06:05 PM   #11
jer301's Avatar
Many Thanks!!
Progressive springs are like having 2 or three springs with different spring rates in one spring. some eibach kits state that the spring rate for some of the progressives are 100-260 lb/in. what this means is that at the low spring rate you have a comfortable ride at normal driving speeds and the higher spring rates will provide quicker response at higher speeds for preformance.
Offline
Old Oct 9, 2009, 01:48 AM   #12
Thanks
but then the front number is lower then the stock.. does that mean corning with low speed will be affected...??
I wonder is Sportline also a progressive design... that give me 1.7F and 1.2R.... something in between the Tein and Tanabe....^^
__________________
- Advan RS Gold
- 25% Tint
Online
Old Oct 9, 2009, 05:48 AM   #13
jer301's Avatar
no. they ride fine @ low speeds. You don't transfer as much weight when cornering at low speeds so it should not feel to soft. The springs job is to keep the tire in contact with the road surface.
Offline
Old Oct 9, 2009, 08:44 AM   #14
cool~
btw which spring are you using...??
I heard that the some user compliant about the sportline kit for the sound.... wonder will pro-kit create sound...^^"
__________________
- Advan RS Gold
- 25% Tint
Online
Old Oct 9, 2009, 09:16 AM   #15
jer301's Avatar
cool~
I decided not to replace my springs. I was working on my own suspension design and got as far as roll stiffness, but quit. If i replaced my springs it would take me out of stock class for autox. That being said if you want my calcs pm me your email and I will email them to you. very strait forward and I explain everything in detail. the Tien S progressive springs make noise too. this is on the lower spring rate portion of the spring where the springs are wound closer together. there are rubber isolators you can buy and install on the spring to minimize this.
Offline
Tags
2009, es, evo, lancer, mcpherson, motion, pn, progressive, ratio, springs, stiffer, strut, tanabe, tnf136, uk
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
