Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 2, 2009, 06:15 PM   #1
Personal Sales Rating: (0)
Drives: 2009 Mitsubishi Lancer
GTS 18" wheels on my DE
If I replace my stock 16" wheel with GTS 18" wheels do I need to bring my car back to the dealership so they can adjust the computer for MPG, speedometer, etc...?
Offline
Old Jul 2, 2009, 06:45 PM   #2
Personal Sales Rating: (30)
EVO8904's Avatar
Drives: 09 Lancer GTS
I don't think so.
__________________
EVO VIII traded-in for a 2007 Mitsubishi Outlander XLS
Offline
Old Jul 3, 2009, 02:14 AM   #3
Drives: 2008 mitsubishi lancer ES
no need. probably just need an alignment? correct me if im wrong.
Offline
Old Jul 3, 2009, 10:46 PM   #4
JHizzle's Avatar
Drives: Evo X GSR,08 GTS (for sale), and a K20 again.
lol what would changing wheels have to do with adjusting your speedometer?
to answer your question. no..if you went with too wide a wheel your speedomoter would read slightly more or less than you are actually going. if changing wheels made that much of a diff a lot of ppl would have stock cars..
going from De to GTS wheels you will be perfectly fine.
Online
Old Jul 4, 2009, 01:03 AM   #5
Drives: 2009 Mitsubishi Lancer GTS
If you go from a 16" wheel to an 18" wheel your speedometer will be off the faster you go. Just go here and use this calculator to see how off it will be and see if it bothers you.
http://www.discounttire.com/dtcs/infoTireMath.dos
Offline
Old Jul 4, 2009, 08:22 AM   #6
Personal Sales Rating: (1)
evosean's Avatar
Drives: 2006 evolution rs, 2008 lancer gts, 2004 lancer ralliart sportback
your speedo will be dead on, if you buy the right size tire. you will need no alignment
pretty sure that the 215/45 18 that comes on a gts calculates darn near perfect compared to the 16's that came stock.
__________________
346 whp / 310 wtq
stock ecu, pump gas
buschur tune
Offline
Old Jul 4, 2009, 11:09 AM   #7
cRc`22's Avatar
Drives: WW 08 GTS
Send a message via AIM to cRc`22
100% fine.. de es and gts rims + tires are all the same circumfrance
__________________
--Injen Cold Air Intake
--WORKs Drop-In
--Injen SES Exhaust
--WORKS TUNED
--WORKs Rear AntiSway Bar
--HAWK HPS Front Pads
--WORKs 4 Corner SS Brake Lines
--MeganRacing Coilovers
--Enkei RPF1 18x8+35
ForSale :: Stock 08-09 GTS RearSwayBar. upgrade for 08-09 DE/ES models http://forums.evolutionm.net/sale-wh...-bar-20mm.html
Offline
Old Jul 4, 2009, 01:34 PM   #8
JHizzle's Avatar
not true.. the GTS and DE ecu are the same..it cant tell if the car is a GTS with 18 wheels or a DE with 16 inch
Online
Old Jul 4, 2009, 01:41 PM   #9
MasterAK's Avatar
Drives: 08 Lancer ES MT
Just make sure that you take the TPMS sensors from your 16" wheels and put them in the Gts wheels.
__________________
2008 Electric Blue Lancer - 5 spd
☑ Works Rear Sway Bar
☑ HKS Drop-In Filter
☑ 17x8 Rota DPT / Falken FK-452
☑ Rally Armor Basic Mud Flaps
☑ 20% Tint
☑ DDM SlimLine 4500K HID with DRL defeat harness
☑ Fog Light Kit
Offline
Old Jul 10, 2009, 09:33 PM   #10
Drives: 2009 Mitsubishi Lancer DE
Do the DE's come with tpms?
Offline
Old Jul 26, 2009, 12:18 PM   #11
blackdiamonds's Avatar
Drives: 2009 Lancer ES
I have a ES and i might buy a set of GTS 18's and hes selling me everything (tpms) can someone confirm if i need to swap out the Tpms if i get his rims?
__________________
Don't drive faster than your angel can fly.
Offline
Old Jul 27, 2009, 05:45 AM   #12
Drives: 2008 Grey Lancer GTS (5spd)
Send a message via AIM to kalpakiotis
I can't say for 100%, but like 99% yes you will have to either swap with your stock tpms or get the new ones calibrated to your car. The sensors will probably have unique s/n that will have to get paired to the car, almost like bluetooth. Since you'll have a second set, you coula always put them on your snow tires.
__________________
HID Lo/Hi/Fog
RRM SRI V2
RRM TCM
Works Short Shifter
Megan Coilovers...if interested in the stock GTS suspension, pm me.
Offline
Old Jul 27, 2009, 09:40 PM   #13
Personal Sales Rating: (3)
booster9's Avatar
Drives: 06 GG evo 9, 09 RG lancer GTS
noo... mitsubishis TPMS system isnt very advanced.. it reads every sensor, all they do is read air pressure and send to the ecu.. if one is wrong, it throws the light. since the tpms sensor is the same in the ds as it is in the evo, it will all read the same.. nothing different. you can use his, or use yours, you wont need to re-calibrate.. calibration is only for vehicles with wheel specific tpms sensors. which means when your right rear tire is low, it says RIGHT REAR TIRE LOW RR 20 PSI LR PSI 32 LF PSI 33 RF PSI 32.
__________________
EVOLUTION DYNAMICS built and tuned
516hp 430tq @ 32psi -on stock block
ams 2.3L bottom FP top end, no dyno yet
Race it, Break it, Fix it, Repeat
xbox gamertag: TickleMehP1ckle -- on MW2 alllll dayyy long!
Offline
Tags
16, 18, 2008, buy, cal, evolution, gts, inch, lancer, put, rims, speedo, swap, tpms, wheels
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
