Jun 21, 2009, 03:19 AM
Personal Sales Rating: ( 0)
Drives: 2005 Evo & 2008 Lancer GTS
Tires
Hey everyone. I rotated my tires earlier today and noticed that my rear tires were pretty bad. The way or shape one side was thinning or wearing out was really bad (closer to the interior side wall). I was really surprise since these were my rear tires not the front. The front tires were actually not bad but the rear ones I just bought maybe 4 months ago and they are wearing out very uneven. I just wanted to see what everyones thoughts are. My car isnt lowered yet and nothing is done to my suspension at this point. Im saving some cash for my KYB shocks since I already bought the RRM spring. Has anyone experience this?
I appreciate your feedback. Thanks.
Offline
Jun 21, 2009, 03:23 AM
Personal Sales Rating: ( 23)
Drives: 06 Evo MR
Has this happened before? Is this the same for both rears evenly? I have heard of cars coming from the factory with a bad alignment that caused similar situations. Regardless, it sounds like you need an alignment.
Offline
Jun 21, 2009, 03:42 AM
Drives: 2006 Evo 9
The exact same thing happened on my IX when I bought it new with the advans the backs wore out quick from the inner part. When it was time to get a new set I had to get an alignment and rotate the tires more often. Almost two years later and no problems yet.
Offline
Jun 21, 2009, 11:03 AM
This never happened to me before but yes both rear tired are evenly worn out.
Offline
Jun 21, 2009, 11:46 AM
Drives: 2009 Lancer GTS
I think it is your alignment. If the rear wheels are towed in or out slightly, even if it is not noticeable to the eye, when the car accelerates, it will load the rear tires and create negative camber. I don't think its related to your springs or sway bar or you would have noticed alot of body roll in the car when turning.
Offline
Jun 21, 2009, 01:40 PM
Drives: 09 GTS
Yeah a good alignment and camber setup can save your tires and also help out with handling to.
Offline
Jun 21, 2009, 08:26 PM
Drives: Lancer GTS 2008
My friend and my dealer have both told me that the 08 Lancer does not need an alignment, as there are no setting to be adjusted for the setup, and there can be only one way to install them.
Is this true?
__________________
Rally Red 2008 Lancer GTS CVT
Offline
Jun 21, 2009, 09:26 PM
Drives: 08 Lancer GTS
I just changed my pirellis b/c of this. all 4 of them were like that.
the told me it was due to driving hard and my alligment was messed up cause i never got an alligment after I replaced one of the struts.
to prvent this get a good alligment and balance and rotate your tires more often...tires are expensive so take care of them
I ripped thru a set of pirelli p zero neros in 20,000 miles...and I don't drive that hard...i think
__________________
08 GTS F/L
[ X] RRM intake
[ X] RRM pulley
[ X] tinted headlights
[ X] non- scratched tints
[ X] Debadged rear
[ X] 18' enkei evo 5's
[ X] RRM rear swaybar
[ X] smoked tail lights and side markers
[ X] RRM rear sway bar
[ X] tein s-techs
[ X] RRM test pipe
[ ] a good paying job
Offline
Jun 22, 2009, 01:13 PM
Thanks for the input everyone. Im also waiting for my KYB Struts from RRM. Once I drop my car, I'll get cambers from RRM and get my alignment done.
Offline
Jun 22, 2009, 01:46 PM
Drives: 2005 EVO VIII
alignment
Offline
Jun 22, 2009, 07:59 PM
Personal Sales Rating: ( 1)
Drives: 2008 Grey Lancer GTS (5spd)
Quote:
Is this true?
idk what your dealer is smoking, mine did an alignment for me a while back..found that the toe was out on both front tires which was causing that inner tire wear. Havn't noticed anything yet...keeping fingers crossed
__________________
HID Lo/Hi/Fog
RRM SRI V2
RRM TCM
Works Short Shifter
Megan Coilovers...if interested in the stock GTS suspension, pm me.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
