Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 18, 2009, 01:27 PM   #1
Personal Sales Rating: (0)
2009 Mitsubishi Lancer
wildes56's Avatar
Drives: 09 lancer
tpms on new rims
I have a question about the tpms I am planning on getting new rims but I don’t know how this will affect the tpms will it go crazy is there a way to shut it off or something
I know there is a lot of guys running new rims just want to see what you guys did i have already seen the other thread just wanted to see if any solution has been found
Offline
Old Jun 18, 2009, 03:01 PM   #2
wildes56's Avatar
Drives: 09 lancer
part 2
can i take the ones out of the es rims and put them on new rims ?
Offline
Old Jun 18, 2009, 03:23 PM   #3
2008 Mitsubishi Lancer
SirLancerlotWPG's Avatar
Drives: 2008 Mitsubishi Lancer GTS
Took the sensors out of the old rims, and put them on the new ones before I had the rubber installed. Works fine, you just need to unscrew the sensor from the inside of the rim.
Offline
Old Jun 18, 2009, 03:24 PM   #4
forgot to add; Check the sticky regarding this issue:
TPMS - the ultimate FAQ
Offline
Old Jun 18, 2009, 03:39 PM   #5
wildes56's Avatar
Drives: 09 lancer
ya saw that just need to clear things up is it really that easy as unscrewing it from the rim
Offline
Old Jun 18, 2009, 09:31 PM   #6
Quote:
Yup, just need a ratchet or wrench to unscrew it.
The nut has a rubber seal on the end of it i believe, or the sensor itself.
Offline
Old Jun 19, 2009, 10:14 AM   #7
wildes56's Avatar
Drives: 09 lancer
Thanks for the help guys
Offline
Old Jun 19, 2009, 12:37 PM   #8
MasterAK's Avatar
Drives: 08 Lancer ES MT
I took my sensors from the old rims and put them on the new rims. However fitment is not guaranteed. The stock rims had a machined, flat hole that assures that it won't leak air. In many aftermarket wheels however, (mine included), the hole was located along the crease and it wasn't machined flat. 3 of my wheels were leaking air and the guy who mounted my wheels and tires had to change the small O ring and put a thicker one and it finally worked.
__________________
2008 Electric Blue Lancer - 5 spd
☑ Works Rear Sway Bar
☑ HKS Drop-In Filter
☑ 17x8 Rota DPT / Falken FK-452
☑ Rally Armor Basic Mud Flaps
☑ 20% Tint
☑ DDM SlimLine 4500K HID with DRL defeat harness
☑ Fog Light Kit
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
