Jun 3, 2009, 10:51 AM
Personal Sales Rating: ( 0)
Drives: 2009 Mitsubishi Lancer GTS
225/45/18 - On Stock GTS Wheel
Guys I am in need of new tires and want to get some Potenza RE960AS Pole Position tires but the closest size I see is a 225/45/18. Will that fit on a Stock GTS 18" Wheel?
Offline
Jun 3, 2009, 12:04 PM
Personal Sales Rating: ( 7)
2007 Subaru Impreza
Drives: Robut bear cavalry to the bearpocalypse
Isn't the stock wheel only 7" wide?
Offline
Jun 3, 2009, 01:36 PM
Drives: 09 Lancer GTS M/T
yep
Online
Jun 3, 2009, 01:49 PM
Drives: '08 lancer gts
Should fit.
Offline
Maybe try a 40 series tire.
Offline
Jun 3, 2009, 01:52 PM
Personal Sales Rating: ( 35)
Drives: RC Cars!
You should try 235/40/18.....seems like it would fit better and look better!?!?!
225 is SMALL and with a 225/45, DeNG!!! I would think it that be awkward. \:
Offline
Jun 3, 2009, 03:51 PM
2007 Subaru Impreza
If the stock wheels are only 7" wide though a 235 won't fit, at least not properly.
Offline
Jun 9, 2009, 09:02 AM
Sucks because the Potenza RE960AS Pole Position tires don't seem to come in a size that will fit our stock wheel.
Offline
Jun 9, 2009, 04:54 PM
Drives: 09 white lancer gts stock =(
i called tire rack once becuase i had the same question and they told me that a 225/45/18 would fit without any rubbing on turns or anything.
Offline
Jun 12, 2009, 11:23 AM
Personal Sales Rating: ( 1)
Drives: WW 08 GTS
a few people have threads on here saying they have 225/45 tires..
__________________
--Injen Cold Air Intake
--WORKs Drop-In
--Injen SES Exhaust
--WORKS TUNED
--WORKs Rear AntiSway Bar
--HAWK HPS Front Pads
--WORKs 4 Corner SS Brake Lines
--MeganRacing Coilovers
--Enkei RPF1 18x8+35
ForSale :: Stock 08-09 GTS RearSwayBar. upgrade for 08-09 DE/ES models http://forums.evolutionm.net/sale-wh...-bar-20mm.html
Offline
Jun 12, 2009, 11:40 AM
Drives: Apex Silver 2008 Lancer GTS
I think you need to take another look at what the numbers on a tire mean.
225/45r18 tire is WIDER than a 215/45R18 that comes on the GTS. The tire is 10mm wider to be exact and 45(height of the sidewall) is 45% of the cross section of the tire. In effect he is running a WIDER and TALLER tire so no that tire is not small. a 235/40R18 is closer in overall diameter to the stock tire however the rims are too narrow for this tire to fit properly. A 225/45R18 or 225/40R18 tire will work. The 225/40 will make your speedometer off a bit more but should be ok. Ummm I think DiscountTireDirect as a size conversion chart to show you how much your tire size effects your speedometer.
__________________
RRM SRI Intake
RRM Rear Strut Tower Bar
RRM Carbon Fiber Mirror Covers
RRM Carbon Fiber Splitter
RRM Emblem on rear
RRM Timing Module
Partially Debadged rear
Limo Tint on rear
Vortex Generator
Nikon D80 with Nikkor 18-55mm lens and 55-200mm lens.
Offline
Jun 14, 2009, 12:15 AM
Drives: 2005 Evo & 2008 Lancer GTS
I went with the Perrilles. Same size.
Offline
Jul 6, 2009, 03:49 PM
Drives: 2009 Lancer GTS, R R
I've been running some Continental (sorry, our cars are -not- fast enough to rate a 150 dollar tire) 225/35/18's on my GTS with no problems. The speedometer is only off by about 2mph+ at 60mph so it's not very bothersome.
__________________
Custom Exhaust | RRM SRI v2
ARS Evo X Overlay | RRM Piggyback
DIY Painted Rims (Plasti-dip)
Eibach Sportlines | Tinting heads/tails soon.
9G Lancers - Check us out..
http://9glancers.com/index.php?referredby=1471
Offline
Aug 6, 2009, 06:08 PM
Drives: honda
should fit fine. good luck
Offline
Aug 12, 2009, 03:53 PM
Drives: 2008 Lancer GTS
I bought some Cooper Zeon 225 45 18 a week ago and no rubbing anywhere. Full lock or not. And, they look good to.
Offline
Tags
18, 2009, 225, 2254518, 45, chart, evo, fit, gts, lancer, rims, size, stock, tire, wheel  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
