Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 1, 2009, 10:20 AM   #1
Personal Sales Rating: (3)
xpehbam's Avatar
Drives: 04 Galant GTS, 3.8 - Sold!!! Blue 06 Evo IX!!! 2009 Honda Accord V6
Stock evo suspension on the ES? I know front fits Is there any way to fit the rear?
Stock Evo suspension on the ES? I know front fits Is there any way to fit the rear?
Offline
Old Jun 1, 2009, 05:08 PM   #2
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
You would need to use Evo rear lower control arms and have the upper strut mounts cut out and have the Evo upper strut mounts welded in. You will also lose your rear sway bar as the Evo's rear sway bar endlinks are mounted to their rear upper control arms (which Lancers don't have.
Offline
Old Jun 2, 2009, 06:05 AM   #3
Personal Sales Rating: (7)
blaze_125's Avatar
Drives: Yellow OZ
Quote:
Drill a hole through the lower control arm... tadam. you've got your sway bar hooked again.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Old Jun 2, 2009, 06:45 AM   #4
Quote:
Technically you would also need to either machine out a hemisphere on the top and bottom of the arms also to allow for proper seating of the bushings. Or you could use different end links and use a bracket to connect them to the LCAs. I'd be less concerned about losing the sway bar and more concerned about the structural work being done in the trunk to relocate the rear strut towers.
Offline
Old Jun 2, 2009, 04:18 PM   #5
Personal Sales Rating: (1)
Juan Martinez's Avatar
Drives: 03 Mitsubishi Lancer Oz Rally, 04 Mitsubishi Lancer ES
Send a message via Yahoo to Juan Martinez
No, you can't fit it on the rear, unless you replace the top strut mounts with evo ones, which means you cut out all the sheet metal support and put in the new. As for the lower control arms, some of the older ones they made aftermarket for the older 95-01 mirages might work if you used a different strut.
__________________
Build Thread http://forums.evolutionm.net/lancer-...ld-thread.html
Check out my rides at
http://www.cardomain.com/id/k_dog007
03 Lancer OZ Rally
04 Lancer ES
98 Eclipse RS (Traded in July 2007 for 04 Lancer)
01 Mirage ES (Traded in on Eclipse in 2005)
85 Pontiac Fiero (never made it on the road, sold 2004)
93 Eagle Summit ES (Traded in in July 2003 for 01 Mirage)
Offline
Tags
2009, evo, suspension
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
